Thread: Fabia SDi - Problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Fabia SDi - Problems
    Feb 2009
    Preston
    Hi All,
    Used this forum alot to help me with various things here and there but now I have become very stuck and need some advice/help!
    I have a 2002 Fabia SDi - It has a few problems:
    Rough running when started
    Blows out loads of smoke when driving along
    It has been like this since I purchased it. I have run a few tests on VAG-Com (attached) which leave me a little puzzled.
    I'm going to start with changing the Fuel filter, T-Piece and giving it a good service but the test leave me thinking that its either the injectors are gone or the timing is out.
    Any help at all appreciated!
  2. Re: Fabia SDi - Problems
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    try unplugging your MAF sensor and going for a run.
    Sorry just realised it's SDi , don't think they have a MAF sensor. Check for air getting into the fuel at the filter connections, worn camshaft, I think pump timing looked ok on VCDS, consider a compression and injector test once you've exhausted the easy cheap options. Possibly fuel pump fault which could be expensive. how many miles has it done?
  3. Re: Fabia SDi - Problems
    134 Post(s)
    1999 Post(s)
    What are the binary values in fields 2 and 4 of group 017?
  4. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Hi Rob 69 - I don't think my SDi has a MAF but i will double check and try if it does.
    Hi Crasher, I did not read that value, I will tonight when I get back after the drive home. Are there any other groups I should get data from to help?
    Thanks!
  5. Re: Fabia SDi - Problems
    134 Post(s)
    1999 Post(s)
    The groups with useful data are
    Ignition on engine NOT running
    006 block 2
    007 block 1
    019 blocks 1 & 2
    At idle
    000 blocks 1, 2, 3, 4, 6, 7, 8 & 9
    001 blocks 1 > 4
    002 blocks 2 & 3
    003 block 4
    004 blocks 2 > 4
    013 blocks 1 > 4
    016 blocks 2 > 4
    WOT, hot in 3rd or 4th gear @ 3K rpm
    000 1 > 4 & 6 > 9
    004 2 > 4
    008 2 >4
  6. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Crasher, hope I have done this right!
    Pic 1 - Ignition on 006/007/019
    Pic 2 - At idle cold 000/001/002
    Pic 3 - At idle cold 003/004/013
    Pic 4 - At idle cold 016
    Pic 5 - At idle warm 000/001/002
    Pic 6 - At idle warm 003/004/013
    Pic 7 - At idle warm 016
    Pic 8 - 3000rpm of there about in 4th gear - 001/004/008
    Also, log of 001/004/008 whilst driving home, the beginning of the drive was fine, then lots of smoke!
  7. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Pic 6/7/8 - log won't upload here.
  8. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    Ok, I'm going out on a guess here, however reading around and looking at all the logs it looks to me that the timing is out due to an incorrectly fitted cambelt?
  9. Re: Fabia SDi - Problems
    134 Post(s)
    1999 Post(s)
    I don't like what injector 4 is doing and 004/3 is way out under load so yes, COI and valve timing.
  10. Re: Fabia SDi - Problems
    Feb 2009
    Preston
    So, just to sum this up,
    COI (what is COI short for? *Commencement of Injection*) and valve timing - Get the cambelt done and the timing adjusted correctly (It's due a change in 2017 so may as well get it done now!)
    Injector 4 - Keep tabs on this after a belt change and see what happens - maybe replace?
    Last edited by cool_dood01; 15-12-2016 at 11:15 PM. Reason: Commencement of Injection
  1. Please Help Fabia immobiliser problems
    By kateb in forum Fabia
    Last Post: 11-08-2015, 08:54 AM
  2. Please Help Fabia 1.9 SDI - running rough, no power, is it the ecu?
    By GRAHAM COGSWELL in forum Fabia
    Last Post: 05-01-2013, 07:52 PM
  3. 2005 mk 5 sdi problems
    By mbev51 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-10-2009, 02:01 PM
  4. Question How reliable is a 2000-2001 Fabia 1.9 SDI
    By harry100 in forum Fabia
    Last Post: 21-07-2009, 06:07 PM
  5. Fabia 1.9 SDi Starter Motor
    By deputy899 in forum Fabia
    Last Post: 04-12-2007, 11:37 AM
