Thread: Terrible mpg when car is cold
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. Terrible mpg when car is cold
    Jun 2008
    7 Post(s)
    Hi All looking for some help or advice.
    2008 Audi A4 2.0TDI CAGA engine
    A few months ago I change the cambelt and water pump and followed everything to the book, but ever since then I have suffered with bad MPG when the car is cold and on short trips averaging between 20 - 30mpg, on long runs everything seams to be normal averaging between 48 - 54mpg dependent on speed.
    the above figures have been reached using tank fill meathead, but what I have noticed is when looking at the did display it shows 15mpg when first started and struggles to get to 30mpg when cold where before the cambelt was changed it would read 15mpg when first started but would then quickly move up above 38mpg and above.
    the above problems seem to be like too much fuel is being injected into the engine but there is no singe of smoke or rough running at all if anything the car feels better with lots of power thought the rev range. One thing I have noticed though is the temp gauge is taking some time to get up to temp, I have changed thermostat but am wondering if the problem could be with the temp sensor?
    I have scanned the car and all is good without faults and captured some data which seems fine also.
    Please see attached images. I hope you may be able to throw some light as to why I am having this problem and if there are any other tests I can do to find the problem
  2. Re: Terrible mpg when car is cold
    Dec 2014
    Bedford
    42 Post(s)
    Sounds normal to me.
    Sent from my SM-G900F using Tapatalk
  3. Re: Terrible mpg when car is cold
    Pembrokeshire
    22 Post(s)
    maybem just maybe, you have the timing slightly out..
  4. Re: Terrible mpg when car is cold
    2005 Post(s)
    What did you lock the cam and crank with?
    0 2 0
  5. Re: Terrible mpg when car is cold
    Jun 2008
    7 Post(s)
    Hi Crasher & Zollaf
    I used the locking tools as to Elsawin and set as instructed.
    I have logged with hot engine.
    IDE00021 Engine speed 836 /min
    IDE00405 Crankshaft speed (RPM) 839.5 /min
    IDE00406 Camshaft speed (RPM) 418.3 /min
    ENG106252 Synchronous angle 0.00 °
    from what I can see with Synchronous angle the timing looks to be spot on.
    This one has got me baffled.
  6. Re: Terrible mpg when car is cold
    Oct 2016
    Essex/Hertfordshire
    15 Post(s)
    Did you own the car last winter? My old 2.0TDI easily dropped 10mpg in winter on a 15 mile trip i did a fair bit
    Sent from my SM-G935F using Tapatalk
  7. Re: Terrible mpg when car is cold
    Jun 2008
    7 Post(s)
    Had the car from new, There is a problem the car is drinking fuel when cold and dong short trips or stuck in traffic.
  8. Re: Terrible mpg when car is cold
    Dec 2014
    Bedford
    42 Post(s)
    My usual weekly commute in my 1.9 pd is £30. Last week same commute £45. I brim the tank every Sunday and that's how I know. It's down to the recent cold spell.
  9. Re: Terrible mpg when car is cold
    2005 Post(s)
    Check the actual coolant temp in measuring blocks when you are cruising at a steady speed, don't take any notice of the dash display, look at in in engine 01.
  10. Re: Terrible mpg when car is cold
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Don't those CR engines have two stats in the system ??
    My 1.9 PD engine mpg has tailed off recently and a check with VCDS showed temp at low 70's even though dash says 90' and stat set point is 85'. stat change coming up after christmas to hopefully improve mpg, all else looked ok on my engine.
  1. Terrible getaway car.....lol
    By Gerryf in forum Golf MK7 - 2013 - 2019
    Last Post: 29-07-2013, 07:56 AM
  2. golf gt tdi 140 terrible mpg
    By mario.cy in forum Golf MK5 - 2004 - 2009
    Last Post: 02-04-2013, 01:02 PM
  3. Terrible MPG
    By Nutkin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2011, 10:03 AM
  4. Please Help loss of boost in 6th gear, terrible mpg!
    By robert1z in forum Golf MK4 - 1999 - 2004
    Last Post: 22-11-2010, 08:57 PM
  5. Question Terrible MPG after new turbo fitted ?
    By fastbikes76 in forum Touran - Sharan - Caravelle
    Last Post: 05-05-2010, 09:54 PM
