Thread: Diesel owners , Glow Plugs
  1. Diesel owners , Glow Plugs
    Bristol
    I checked my glow plugs operation this am , as i noticed she seemed to take longer cranking in cold conditions,
    I removed and tested them all and all, yes all the glow plugs were open circuit
    Couldnt beleive it , each one had gone
    I guess they are nearly 8 years old and I should have checked them before now !!!!
    Strange thing is no fault code !!!!
    Anyway , check your glowplugs, ready for winter
    MK5 Golf TDI 2.0ltr GT Sport in Black
  2. Re: Diesel owners , Glow Plugs
    Aug 2007
    Northern Ireland
    After reading a few threads over on TDiClub it has opened my eyes about how careful you should be when removing them. Even the slightest of sideways pressure is enough to dislodge the hexagon part from the long cylindrical piece, then you will need to spend more than just a few minutes changing/testing glow plugs. This will also happen if the plug threads seize to the head.
    Be careful, be very careful! and dont forget to put some sort of anti-seize compound on the threads when refitting.
    I personally would not remove the plugs to test them, instead I would check current draw / continuity in situ.
    In extreme cases you could (cowboy method) just remove the bus bar/wires to the plugs and touch the top of the plug with it while the ignition is on the pre-heat position. If there's a spark there's a good chance the plug is ok.
    Don't get me wrong CBRPaul - Great idea to check your glowplugs coming into winter, just I wouldn't recommend taking them out to check
    Pete
    52 plate Golf GT TDi
  3. Re: Diesel owners , Glow Plugs
    Canada
    Easiest test is disconnect bus bar, use a multimeter between top and engine, if it reads about 1ohm all is good anything else its dead
  4. Re: Diesel owners , Glow Plugs
    Bristol
    Quote Originally Posted by mobitune View Post
    I personally would not remove the plugs to test them, instead I would check current draw continuity in situ.
    Pete
    Some good points worth mentioning to anyone not having not done this sort of thing before ,
    Maybe i should have worded my post abit better though (ala removed bus bar 1st to test ) ,
    I tested my plugs exaclty as robs post below , they were then only removed due to being faulty , there is no need to remove to test , quite right Rob
    Quote Originally Posted by onzarob View Post
    This is the first step in testing the plugs before removing
    Having worked on many cars over the last 30 years or so , My post was just m intended to just make peeps aware of potential problems in winter with glow plugs , not a " HOW TOO " as such ,
    So if you are not familiar with doing this sort of thing , take it to someone who is !!!!
    As mentioned above , damage can occur !!!
  5. Re: Diesel owners , Glow Plugs
    135 Post(s)
    2040 Post(s)
    The reason you don't get a fault code is the ECU has no way of knowing if the glow plugs are working or not. If they snap off it is a nightmare to get them out.
  1. Glow plugs dont switch on
    By ghee60 in forum 80 - 90
    Last Post: 26-08-2009, 12:02 PM
  2. 2.4 Caravelle Glow Plugs
    By cleavee in forum Touran - Sharan - Caravelle
    Last Post: 26-10-2008, 05:28 PM
  3. fuse for glow plugs?????
    By paulyatt in forum The Commercial Range
    Last Post: 04-10-2007, 08:38 AM
  4. glow plugs...wiring diagram
    By DieselBenjamin in forum 80 - 90
    Last Post: 24-08-2007, 08:46 AM
  5. Glow Plugs on a '94 Golf TD
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 08:01 PM
