Thread: Audi A4 B6 130 6sp Quattro Wandering Issue
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2016
    Fakenham, Norfolk
    Hi All
    Firstly many thanks in advance for anyone that replies to my post, so the story goes...............
    I have a 2003 quattro 130 tdi, when i first bought the car, this being my 1st 4x4 audi, i was so impressed with how it handled and went round bends ! it stuck like glue !
    but over the last few months it has somewhere developed an issue that i just cannot find, to replace what ever needs replacing. so i'm hoping someone has had the issue before and can point me in the right direction.
    Driving along at normal speeds on nice normal flat roads, it drives fine, but as soon as the road is slightly uneven, or has grooves running in it from years or wear & tear on the tarmac / asphalt, the car wanders the road, like something is pulling against the steering and making it difficult to keep in a straight line, or if you go to overtake a another vehicle and cross the white lines, where the tarmac slightly over laps you notice something is not quite right too, it pulls slightly one way.
    I have investigated around the front suspension & control arms, initially they looked aged with a tiny bit of movement, so i bit the bullet and bought a complete set and replaced them all for new. But it still wanders the road. I have had both rear wheels off, and again checked all bushes / connections, and these all seem to be solid......
    i have had the tracking, 4 wheel alignment checked, and this is fine...........
    the track rod ends seem good, with no abnormal movement, there is no play in the steering wheel.....
    wheels bearings on all 4 seem good with no play or weird noises...
    so as you can imagine i cant work out whats causing this, so i'm hoping someone has had a similar issue before, or at least point me in another direction to look at.....?
    Thanks again for reading my post
  2. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2009
    southampton uk
    Have you tried swopping the tyres back to front?My 2.5tdi Q used to do this but it was a lot better after I swopped the 16s to 18s
  3. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2016
    Fakenham, Norfolk
    To be fair i haven't, but the car has got later A4 18" original Alloys on, all tyres are bridgestone with 4-5mm tread, surely the tyres wouldnt be causing this ?
  4. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2009
    southampton uk
    Agreed its unlikely but you seem to have tried everything else.Otherwise I would get the tracking done again unless you are 100% happy with that
  5. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2016
    Fakenham, Norfolk
    I'm happy with the tracking, i was watching as they did it, plus i had a mate at another garage just check the fronts, that's what prompted me to having 4 wheel alignment, i do have an octavia mk1 with decent alloys on, i might check the stud fitment and whip them off one day onto the audi to test.....as you say there is much left it could be....
  6. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Dec 2007
    8 Post(s)
    Out of shape tyres could cause wander
  7. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Its not only the depth you need to look at but check the whole circumference of the tyre cross section for strange wear patterns. Its not always so obvious if you have a faulty tyre. It would be one of my first checks anyway.
    Alan.
    VW T6 150 DSG Camper £££
  8. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Jul 2015
    Staffs
    46 Post(s)
    Try and find a helpful soul whome you can swap wheels with. Give them some beer money, and see how it feels.
    Ian
    A4 B6 Avant Nogaro Blue
  9. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Your stud pattern will be 5x112 as will the Skoda, but there may be a difference in ET , ie the amount that the wheel sticks out from the strut assembly.
  10. Re: Audi A4 B6 130 6sp Quattro Wandering Issue
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    ET should also be stamped or cast on the wheels along with the stud pattern
  1. Audi 80 quattro coil issue
    By mac80 in forum 8v - Engine
    Last Post: 30-03-2016, 08:06 PM
  2. Audi A4 B6 1.9 130 quattro build.
    By GuitarGuy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-10-2014, 11:46 AM
  3. Audi A6 Avant SE 177 SE 6Sp Manual 2012 Mud Flaps C7
    By burningoil in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-05-2014, 04:33 PM
  4. newbie 1995 audi a4 tdi steering wandering
    By tezo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2012, 11:53 PM
  5. Please Help A3 1.9TDI 130 6sp Gearbox Oil Filler?
    By Smak in forum Audi A3 - Archive Topics
    Last Post: 12-08-2008, 10:49 AM
