Thread: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
  1. 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Jul 2015
    Norway, Oslo
    Weather has gotten quite cold here in Norway during the last month, and during this period our 07 A6 2.7 TDi has developed (or maybe it's always been like that - got the car this summer in warm weather) kind of a humming or vibrating noise - or just very noisy engine rattle.
    This is almost only noticeable when started in cold weather (like +5 Celsius), AND typically most prominent when going slow in 2nd or 3rd gear and going off the accelerator. Like when you've gotten up to speed and slowly take the foot of the accelerator and the rpms decreases. Seems to be happening most on rpms between 1200-1500. Like a loud engine humming, or some kind of resonating noise...Like somehting is vibrating...Hard do describe - as always with car noises
    I am not able to reproduce this noise with car in neutral and slowly pressing and/or releasing the accelerator. It is ONLY when car is in gear and moving.
    It is almost not noticeable when engine has reached operating temperature.
    Any immediate thoughts? Intake manifolds? Gearbox?
    I've done ALL work myself on all my previous vehicles (all Saabs and Citroens), but looking under the engine cover on the Audi I was blown away on how little space there is to get around things. Also - I've never worked on a diesel engine before - so I feel kind of helpless
  2. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    glasgow
    35 Post(s)
    Firstly you simply lift off the engine cover and all parts like diesel filter, oil filter are quite easily accessible .
    Run car with cover off and see if you still have a rattle, there are 3 or 4 points on the cover that have rubber gromets and they maybe are perished
    Failing that start car and look and listen for any pipes disconnected.
    All diesels have a " diesel knock " when cold. As the engine warms up, this will decrease.
    When was the last service for the engine oil & what oil is in it ?
    I change my diesel filter every 20,000 miles as they don't have drains for water, this will make your diesel freeze .
  3. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Jul 2015
    Norway, Oslo
    Thanks for your reply.
    I've tried to listen for various pipes disconnected etc, but as I wrote - the sound only occurs when car is in motion and in gear. That makes it a lot harder - because as soon as you are moving - wind noise in your ear as you lean out of the window effectively disrupts most noises from the engine compartment.
    I know diesels have a knock when cold. This is is with no doubt somehting different.
    Car was last serviced about a 1.5 years ago (long life service) by the previous owner. On the printout it only service "long life oil, 50700B" ...
  4. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    glasgow
    35 Post(s)
    Can you jack the car up on axle stands, switch engine on and engage a gear ?
    Is the noise in the gearbox or at the wheel ? Nothing to do with brakes , as in the brake disc shield isn't touching the brake disc ?
    Is there a noise if you turn the steering wheel over to the left or right ?
    How many miles has your car done ?
    Have you changed the transmission oil/ gearbox oil ?
  5. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Jul 2015
    Norway, Oslo
    While I do have had cars on four axle stands before, I'm not that comfortable with such a setup that I feel comfortable running the car while it's up there. Maybe I'm just paranoid...
    I'm unfortunately not able to determine exactly where the noise is coming from. However, I'm very confident that it is not coming from the wheel areas, neither is it related to the servo-pump or steering in general. I've replaced several servo-pumps and steering racks on other cars, and this is definately not something like that.
    It feels exhaust or turbo related. I suddenly remembered I had something similar on my Saab 9-5 couple of years ago - it made this "humming" noise when engine was pushed on lov revs and high gear. That turned out to be the turbo bypass valve - or often refered to as the "hooter"-valve on petrol turbo cars.
    Do these Audi diesel engines have such a valve? I realize I have to read up on turbo-diesel engines..
  6. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Mar 2013
    Lincolnshire
    Can you scan with VCDS? Could it be the engine mount solenoid valve being faulty?
    A6 2008 57 Reg 2.7TDi SE Tiptronic Avant Quattro
  7. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Jul 2015
    Norway, Oslo
    I'll do a VCDS scan as soon as I have the time.
    Engine mount solenoid valve ? Never heard of such a thing. What does it do?
  8. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Mar 2013
    Lincolnshire
    Copied from another site:
    the way the mounts work is that there is a fluid chamber with a plastic body in the middle of it, with small channel cut through it. this allows fluid from the top chamber, through the plastic body, to the bottom chamber. the bottom chamber is rubber lined and can deform under pressure. there is also an airway vented to atmosphere, with a rubber membrane separating the fluid from the atmosphere. a solenoid valve, controlled by the motronic, can open or close the airway.
    below 1100 rpm (i.e idle), the engine vibrations are not enough to force fluid from the top chamber, through the passageway to the bottom chamber. the airway is open (solenoid valve open). the rubber membrane creates a soft cushion which absorbs the high frequency vibrations.
    above 1100 rpm the soleniod valve is closed which blocks the airway and so "hardens" the mount (the fluid has nowhere to go). thus the mount is effectively solid.
    the high frequency vibrations at speed are absorbed by the membrane (as in the idle case), while the more damaging low frequency vibrations cause the fluid to force itself through the chamber in the plastic body to the lower chamber, forcing the (lower) rubber chamber to distort - effectively absorbing the vibrations.
  9. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Nov 2012
    Somerset UK
    Tiptronic tranny fluid/filter change according to zf should be done at 50k miles thereafter. Dirty or low fluid will not show on a VCDS scan.
  10. Re: 2007 2.7 tdi aut. - humming, resonating noise on low rpms when cold
    Jul 2015
    Norway, Oslo
    Got around doing a VCDS scan today.
    What gets me a little worried is the glow plug faults. But they are dated half a year back...??
    Copied the modules with faults from the log :
    Thursday,05,November,2015,11:59:04:62939
    <snip>
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F7 910 401 D HW: 4F0 907 401 C
    Component: 2.7L V6TDI G000AG 0020
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 758 00200
    VCID: 24470A1BE72E243ED0B-8071
    4 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 145226 km
    Time Indication: 0
    Date: 2015.04.29
    Time: 17:47:05
    Freeze Frame:
    RPM: 840 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 21.3 %
    Temperature: 15.3°C
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 145226 km
    Time Indication: 0
    Date: 2015.04.29
    Time: 17:47:05
    Freeze Frame:
    RPM: 840 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 21.3 %
    Temperature: 15.3°C
    005660 - Glowplug for Cylinder 3 (Q12)
    P161C - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 145226 km
    Time Indication: 0
    Date: 2015.04.29
    Time: 17:47:05
    Freeze Frame:
    RPM: 840 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 21.3 %
    Temperature: 15.3°C
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 145226 km
    Time Indication: 0
    Date: 2015.04.29
    Time: 17:47:05
    Freeze Frame:
    RPM: 840 /min
    Torque: 128.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.68 V
    Duty Cycle: 21.3 %
    Temperature: 15.3°C
    Readiness: 0 0 0 0 0
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0230
    Revision: 09010701 Serial number: 10601500906415
    Coding: 0000135
    Shop #: WSC 02323 758 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H27 0080
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0060
    1 Fault Found:
    00956 - Key 2
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 3
    Fault Frequency: 52
    Reset counter: 176
    Mileage: 146790 km
    Time Indication: 0
    Date: 2015.08.13
    Time: 08:17:46
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
    Component: Komfortgeraet H26 0210
    Revision: 02100026 Serial number: 01072545550000
    Coding: 3547889
    Shop #: WSC 02335 758 00200
    VCID: 326BFC43ADDABA8E527-8067
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 8
    Reset counter: 171
    Mileage: 147730 km
    Time Indication: 0
    Date: 2015.09.19
    Time: 12:22:14
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000156264
    Shop #: WSC 00493 128 52362
    VCID: 23450907E2202306A91-8076
    Subsystem 1 - Part No: 4F0 915 105 E
    Component: von VA0 57100770SK
    Coding: 34463039313531303545205641303537313030373730534B
    Shop #: WSC 00000 384 00290
    5 Faults Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 145287 km
    Time Indication: 0
    Date: 2015.05.21
    Time: 14:44:36
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 6
    Reset counter: 255
    Mileage: 145287 km
    Time Indication: 0
    Date: 2015.05.21
    Time: 14:51:03
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 145287 km
    Time Indication: 0
    Date: 2015.05.21
    Time: 14:51:13
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 145287 km
    Time Indication: 0
    Date: 2015.05.21
    Time: 14:51:23
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 145287 km
    Time Indication: 0
    Date: 2015.05.21
    Time: 14:51:33
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0017450
    Shop #: WSC 02327 758 00200
    VCID: 2E53E833B9E29E6E36F-807B
    1 Fault Found:
    02110 - Window Regulator Switch
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 185
    Mileage: 148073 km
    Time Indication: 0
    Date: 2015.09.30
    Time: 11:46:05
  1. A6 C6 2.0TDi automatic. Struggling at low RPMs
    By JoeAudi16 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2015, 04:13 PM
  2. Low humming/whirring noise!
    By mtbkitch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-03-2015, 10:41 PM
  3. Replies: 1
    Last Post: 18-11-2013, 11:08 AM
  4. noise resonating through car
    By steveparr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-11-2009, 09:06 PM
  5. strange resonating humming noise
    By sam80quattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-03-2009, 09:22 PM
