Thread: Touareg very bad cold start
  1. Touareg very bad cold start
    Nov 2016
    Southampton
    2.5tdi 55 plate
    Hi Peeps, only had the car from last Sunday 27th Nov, have waited this long to ask the question why does it take so long on Cold Start? once started it will go all day. I have to stop it cranking and set the whole process off again.
    Started by changing the front Brake hoses and front pads. Then moved onto the yucky stuff.
    Today my Son and myself went through the car complete service with all fluids and filters changed, my Son found an in line non return valve before the fuel filter so obviously this problem has been round some time, I am a Marine Engineer BUT I know little about electronic running of a Diesel, my Son has convinced me to get it plugged in to see if their are any codes being held, this I can get done monday, as it cranks there is not one sign of the engine trying to fire, then it starts as if you had just turned the key for the first time??
    Any Ideas please??
  2. Re: Touareg very bad cold start
    Oct 2019
    Basingstoke, Uk
    When service been done ,did you prime filter by Vcds or other scanner? Cold bad start it's related to injectors, hot to CPS.
  3. Re: Touareg very bad cold start
    Nov 2016
    Southampton
    Blimey its only taken 2.5 years to get a reply LOL it was the injector seals, filled the sump with Diesel, car is sold now regrettably. as for priming, it primes as per any other diesel? apart from the real old stuff
  4. Re: Touareg very bad cold start
    Sep 2008
    mostly in the garage
  1. Please Help Touran burning oil and bad smoke when running cold
    By Scottiedogg in forum Touran - Sharan - Caravelle
    Last Post: 02-01-2017, 10:03 AM
  2. A6 2.5 TDI - bad fuel economy and running cold
    By Morgaine in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-02-2013, 03:18 PM
  3. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  4. Bad cold starting - old fuel?
    By DubDick in forum The Commercial Range
    Last Post: 08-05-2009, 09:44 AM
  5. Polo 1.4 60bhp (akk) - bad cold idle
    By achundee in forum Polo - Derby - Lupo - Fox
    Last Post: 15-03-2007, 08:57 AM
