Thread: Boot light not working
  1. Boot light not working
    Nov 2016
    Salisbury, UK
    I have a single light in my boot, it's been up-rated to an LED, and currently won't work.
    * I don't think it's the LED part because I've put a multimeter across the terminal/plug and don't get a voltage.
    * I don't think it's the boot latch microswitch because the dash display shows me the boot is open
    * I can't see a fuse labelled for this.
    Any ideas?
    (I had the same the other day, but noticed it was only because I had the boot open for ages, and when I shut it and opened again it worked. Also I read somewhere to lock and unlock the car 5x, which I did but it did nothing)
    Thoughts?
  2. Re: Boot light not working
    Aug 2014
    Slovenia
    Remove the LED anyway and measure then. It could be that LED is shorted.
    AUDI A4 B8 2.0TDI 2010 100kW CAGB
  3. Re: Boot light not working
    Nov 2016
    Ireland
    Quote Originally Posted by turbozob View Post
    I changed all interior lights to Leds. Now none work inclding boot light. Must have blown a fuse but cant find which one. Any help out there?
  4. Re: Boot light not working
    Nov 2016
    Salisbury, UK
    That was exactly it thanks.
    Broken wire in LED causing short. Have 12v to the terminal, and I'll solder the LED later.
  5. Re: Boot light not working
    Nov 2016
    Ireland
    Quote Originally Posted by Ianevanz View Post
    Same thing happened me. No blown fuse to be found. So the fix is to disconnect the battery for 30 minutes. All sorted when you reconnect it.
  1. Red trunk/boot interior light not working?
    By stjohnsmythe in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-09-2015, 11:02 AM
  2. Rear Brake light on boot stopped working??!!
    By Muff666 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-06-2013, 10:31 PM
  3. Question Boot light not working?!?
    By munchkincoupe in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-10-2010, 02:34 PM
  4. Glovebox light and boot lights not working??
    By KIDDAJOJO in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2010, 06:32 PM
  5. boot light not working
    By abbykyle1 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-12-2009, 04:52 PM
