Re: Chorus 3 radio: Support for multi function steering wheel? –
01-12-2016,07:55 AM
Originally Posted by
SchrodingersCat
1. Does anybody know if there is a fuse that powers the MFSW?
2. If I am to replace the clock spring module, what is the part number of the proper clock spring that I should retrofit?
Thanks again for all your help. :-)
Regarding fuse, its from lhd manual info:
Fuses on the passenger's side
Some of the items listed are only fitted on certain models or are
optional extras
Fuse list
Fuse list
No. Electrical equipment amps
Fuse carrier (black)
1 Vacant
2 Vacant
3 Vacant
4 Vacant
5 Steering column switch module 5
6 Electronic Stabilisation Program 5
Fig. 285 Diagram of
fuse box (left-hand
drive vehicle)
7 Diagnostic connector 5
8 Gateway (diagnostic interface for data bus) 5
9 Vacant
10 Vacant
11 Vacant
12 Vacant
Fuse carrier (brown)
1 CD drive 5
2 Switch module for Audi drive select 5
3 MMI/Radio 10/20
4 Light switch 5
5 Control unit for instrument cluster 5
6 Ignition lock 5
7 Vacant
8 Air conditioner blower 40
9 Steering column lock 5
10 Air conditioner 10
11 Diagnostic connector 10
12 Steering column switch module 5
F looks ok for you...its in german, mufu is mfsw, GRA is normal cruise control, FIS is DIS
Firma KOSTAL:
8K0 953 568 B : GRA, MUFU, FIS (nur bei A5 MJ 2008 bis 09/2007, anderer Airbaganschluss als bei den neueren, das gilt auch fr ohne Index bis Index C, passt auf keinen Fall in den A4 8K!)
8K0 953 568 D : FIS, kein GRA, kein MUFU
8K0 953 568 E : GRA, FIS, kein MUFU!
8K0 953 568 F : GRA, MUFU, FIS, kein ACC!
8K0 953 568 G : GRA, ACC, MUFU, FIS,...
8K0 953 568 J : FIS, kein GRA, kein MUFU
8K0 953 568 K :GRA, FIS, kein MUFU!
8K0 953 568 L : GRA, MUFU, FIS, kein ACC!
8K0 953 568 M : FIS, GRA, MUFU,ACC
Firma VALEO (ab 1/2011):
8R0 953 568 H : FIS, kein GRA, kein MUFU
8R0 953 568 J : GRA, FIS, kein MUFU!
8R0 953 568 K : MuFu-tauglich, GRA, FIS, kein ACC
8R0 953 568 M : GRA,FIS,MuFu, ACC
FL:
8R0 953 568 N : FIS, kein GRA, kein MUFU
8R0 953 568 P : FIS, GRA?, kein Mufu
8R0 953 568 Q : GRA, MUFU, FIS, kein ACC!
8R0 953 568 R : Mufu; GRA; ACC; Side Assist; FIS
8R0 953 568 S : FIS, GRA, MUFU, ACC
Lenkstockhebel und Lenksulenstg mssen vom gleichen Hersteller sein!
8R0...=VALEO
8K0...=KOSTAL
4G0...=VALEO
4G8...=KOSTAL
Welcher Hersteller verbaut ist, ist nur durch Auslesen oder Ausbau erkenntlich!
Die Variante 8K0 953 568 G,M und 8R0 953 568 M,S sind die mit allen Funktionen, 8K0 953 568 M und 8R0 953 568 M,S werden ber den Ersatzteilweg fr den A4,A5,Q5 angeboten.
A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
