Thread: Audi a4 b6 1.9 tdi over heating problems
Results 11 to 20 of 22
  1. Re: Audi a4 b6 1.9 tdi over heating problems
    131 Post(s)
    1976 Post(s)
    £500! What do you have, a slave? VW say don't skim those heads as it removes the anti porosity coating but to do so you have to remove the injectors and valves.
  2. Re: Audi a4 b6 1.9 tdi over heating problems
    Pembrokeshire
    22 Post(s)
    not forgetting that you must replace the bolts for the cam shaft, injectors and rocker shaft as well as the injector seals. thats eating nearly 200 quids into your budget.
    1 1 0
  3. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    newcastle upon geordie land UK
    what if it needs skimmed ?? and is 500 too cheap ? thats what ive been quoted - between 500-600
  4. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    must i replace the injectors ?
  5. Re: Audi a4 b6 1.9 tdi over heating problems
    Pembrokeshire
    22 Post(s)
    injector seals. not the injectors. 25 quid each for genuine bosch seal kit, x 4 injectors, or there is a bloke in poland doing them for a tenner on ebay. all the bolts MUST be replaced unless you like stripping the threads in the ally head. some are 7nm then 180 degrees, silly torques like that.
  6. Re: Audi a4 b6 1.9 tdi over heating problems
    Pembrokeshire
    22 Post(s)
    to do it properly is double your quote. to lift the head and slide a new gasket in is about 500.
  7. Re: Audi a4 b6 1.9 tdi over heating problems
    #17
    Aug 2016
    ive been quoted the following
    300 labour
    100 for skim and pressure test
    60 oil and filter
    50 for new gasket and stretch bolts
    10 for anti freeze
    does that not seem right ?
    ive had the same guy do one on my 18t cupra and it was about the same price
  8. Re: Audi a4 b6 1.9 tdi over heating problems
    #18
    Pembrokeshire
    22 Post(s)
    plus injector seals, all the little bolts in the head, (4x injector bolts, 8x rockers shaft, 10x cam bolts). an elring gasket set is about 75 and the bolts 25, so 50 is a bit cheap. maybe thats just for a head gasket or a cheap head set ?? you did mention you have just replaced the timing belt so i presume he is re using it, as that would add a couple more to it with a water pump.
  9. Re: Audi a4 b6 1.9 tdi over heating problems
    #19
    131 Post(s)
    1976 Post(s)
    I will only fit a new head due to the skimming issue and injector bore wear.
    A cheap BARE head costs £550 or £850 for top quality and using the original springs, keepers, cotters, injector blocks, inlet valves and injectors the rest would be
    Cam kit £250 (with bearings)
    Exhaust valves £42
    Head set £70 (with head gasket and injector seals)
    Head bolt set £20
    Injector bolts £15
    Rocker arm bolts £34
    Rocker arm set £342 (with ball pins)
    Whether you replace the rocker arms or not is your decision but if one takes a chunk out of the cam then the cams warranty is invalid
  10. Re: Audi a4 b6 1.9 tdi over heating problems
    #20
    Aug 2016
    been and got the stuff my self to do it got the following -
    4 x bosch injector seal kits - £10.50 ea
    Victor reinz head bolts - £25
    castrol edge 5W-30 c oil & mann filter
    cam bolts, cam carrier bolts, injector bolts and rocker bolts cam in a t 70 uid from audi - not bad to be fair
    also dont know what gasket im going to need untill the heads off
    and yeah timing belt and water pump done 5 days ago so will be re used
    thanks every one for all your advice im sure im going to get a decent job done now
    ill report back when its all been done
    stilll open to advice though if any one has got any more
    1 1 0
  1. Heating problems
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2013, 01:15 AM
  2. Question Problems with '58 plate VW Golf Mk5 1.9 TDI Heating and Air Conditioning
    By malcolmsharp50 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-04-2012, 10:30 PM
  3. Heating problems
    By hazspike in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2011, 09:43 PM
  4. heating and a/c problems
    By jkalyanji in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-07-2010, 10:41 PM
  5. heating problems
    By mikeybutch in forum Polo - Derby - Lupo - Fox
    Last Post: 18-01-2010, 08:45 PM
