Thread: Audi a4 b6 1.9 tdi over heating problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    newcastle upon geordie land UK
    hi all
    Audi A4 B6 1.9 TDI PD130 - AWX engine code
    so car was over heating du to coolant loss whenever i put my foot down over a couple of miles, ive had the front end off and there was visable leakage from the water pump so got to it and put new belt kit and water pump on the car
    all seemed fine around the doors i did loose a little water but i thought that was just the engine finding its level due to air blocks and the system being drained
    so i topped it up and went out for a good drive after about 10 miles on the motorway doing about 80mph the temp shot up to 110c so i backed off and it fell straight back down to normal running temp (90c) - i pulled over to check the coolant as i got a warning from the dash and i had lost some coolant, not as much as i would loose before i done the water pump but i had lost some and it was very hot with lots of pressure in the system
    its done this a coupe of times now and i cant put my finger on what it my be
    heres what ive done so far -
    t/belt kit
    w/pump
    coolant temp sensor
    thermostat
    any advice is appreciated
    thanks,
    mick
  2. Re: Audi a4 b6 1.9 tdi over heating problems
    Sep 2008
    chester
    17 Post(s)
    The only thing I would suggest is change the stat again,even new one's can be bad,failing that it could be the head gasket,you'll need to pressurize the cylinders up to check for bubbles in the header tank.
  3. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    sorry for sounding stupid but how do i do that ?? is it just a case of getting the car up to temp and watching for bubbles ??
    thanks
  4. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    after some reading through the forums i have took it out for a drive and the bottom hose is stone cold whilst the top is hot - when doing the water pump it was evident that the previous owner has used rad weld could this be a blockage or faulty thermostat ?
  5. Re: Audi a4 b6 1.9 tdi over heating problems
    Sep 2008
    chester
    17 Post(s)
    Could be blocked somewhere,give it a good flush through,to pressure test the cylinder head you'll need to take the glowplugs out and use a dummy glowplug with some compressed air to pressurise each cylinder up.
    1 1 0
  6. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    thanks man - ill do that tomorrow and get back to you
  7. Re: Audi a4 b6 1.9 tdi over heating problems
    131 Post(s)
    1974 Post(s)
    What you describe is the classic symptom for an 8V PD TDI head gasket leak.
    1 1 0
  8. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    well today i have flushed the whole system and i have no blockage also put a new stat in and its exactly the same - cold bottom hose and water boiling in the header tank - only thing left is head gasket, ive got no oil or water mixing am i right in saying its drawing in air through the broken gasket causing air locks and stopping circulation ?
  9. Re: Audi a4 b6 1.9 tdi over heating problems
    131 Post(s)
    1974 Post(s)
    Yes, it only happens under load, blows all the water out of the expansion tank.
    1 1 0
  10. Re: Audi a4 b6 1.9 tdi over heating problems
    Aug 2016
    well its going in on wednesday for gasket and head skim, thats another 500 quid, why not eh ? just done timing belt kit, water pump, drive belts & tensioner, DMF and clutch kit, 4 bottom arms, drop links all around, rear discs and pads, full service, 4 tyres - i feel like crying - oh and glow plugs aswell but thats another thread they are not getting any power
    thanks for all your advice on this subject its much appreciated
  1. Heating problems
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-02-2013, 01:15 AM
  2. Question Problems with '58 plate VW Golf Mk5 1.9 TDI Heating and Air Conditioning
    By malcolmsharp50 in forum Golf MK5 - 2004 - 2009
    Last Post: 04-04-2012, 10:30 PM
  3. Heating problems
    By hazspike in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2011, 09:43 PM
  4. heating and a/c problems
    By jkalyanji in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-07-2010, 10:41 PM
  5. heating problems
    By mikeybutch in forum Polo - Derby - Lupo - Fox
    Last Post: 18-01-2010, 08:45 PM
