Thread: Passat B5.5 running cold
  1. Passat B5.5 running cold
    Apr 2013
    Rugby
    Hi all newb question but my Passat no longer gets up to 90 degrees engine temp just hovers round 60/70 and the mpg seems to have dropped according to computer, the heater still pumps out warm air but to be honest it's never been a great heater so wondering if it's the thermostat that's had it and if so what sort of money to replace ? Many thanks
    Nick
  2. Re: Passat B5.5 running cold
    May 2012
    Everywhere
    308 Post(s)
    Do thermostat and cts .
  3. Re: Passat B5.5 running cold
    Apr 2013
    Rugby
    Thanks for reply,what is cts short for ?
  4. Re: Passat B5.5 running cold
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by linesy View Post
    Coolant temp sensor.
    If you're getting heat from the heater I doubt the stat is stuck open. You would hardly get any heat.
    The drop in MPG coincides with the colder weather.
    Personally i would change the CTS and see.
    Ian
    A4 B6 Avant Nogaro Blue
    1 1 0
  5. Re: Passat B5.5 running cold
    Jan 2006
    Near Basingstoke
    yes, change CTS as it's easy and cheap. If that doesn't make a difference do the thermostat. Use a genuine VAG one. I made mistake of buying a europarts one, only got to 86 degrees not 90. Its a pain to change so do once for sake of an extra £10-15. Temp diff made 3-4mpg difference
  6. Re: Passat B5.5 running cold
    7 Post(s)
    Whilst it is drained down do BOTH the CTS and the stat. They both fail with alarming regularity.
    Unless of course you like buying antifreeze and doing the same job (drain down) twice.
    1 1 0
  7. Re: Passat B5.5 running cold
    Jun 2006
    6 Post(s)
    had similar prob on my AWX. After no success with temp sensor swap I'm going to do the thermostat when I can find the time.
  1. Both fans running from cold
    By Simple Si in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2016, 09:14 PM
  2. Running cold
    By rob-the-viking in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-12-2014, 06:09 PM
  3. Cold running help
    By macp in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-09-2011, 10:13 PM
  4. Running cold..
    By polodub in forum Polo - Derby - Lupo - Fox
    Last Post: 09-12-2010, 12:29 PM
  5. 1996 tdi 90 passat running cold???
    By blakeyboy in forum Passat - Archive Topics
    Last Post: 21-11-2006, 08:32 PM
