Thread: Suspected ABS Unit faulty?
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: ABS Unit
    #21
    Nov 2012
    Somerset UK
    My VCDS version is up to 16.8.3
    Is yours a kosher one?
  2. Re: ABS Unit
    #22
    Feb 2012
    folkestone.uk
    no but been fine up to now
  3. Re: ABS Unit
    #23
    Sep 2011
    Lurking over a keyboard ...
    This is what I make of the values for each channel.
    Channel 1....... 4108
    +00004 = Acoustic Parking System Front installed (PR-7X2)
    +00008 = Acoustic Parking System Rear installed (PR-7X1/7X2)
    +04096 = Multi-Function Steering Wheel installed (PR-1XW)
    Channel 2....... 18
    +00002 = Vehicle Identification Number (VIN) available
    +00016 = Digital Radio (DAB) Video Transmission
    Channel 6...... 15
    Function: Input MMI run-on time (time span between switching off and automatic shutdown of MMI).
    Default with mobile phone prefitting installed: 16 min
    Channel 8...... 0
    0 = Service Menu active
    Channel 11.....37
    +00001 = Owners Manual available
    +00004 = Frequency/Source Change via Function Button active
    +00032 = Climate Control Comfort available
    Channel 12 ....0
    0 = No Telephone
    So you have no factory bluetooth/tel module?
  4. Re: ABS Unit
    #24
    Feb 2012
    folkestone.uk
    Hi Gup.
    Hi Gup.
    I noticed Channel 12 to.
    Yes I have a KUFATEC FISCON bluetooth fitted. This was fitted before I got the car, runs through the car hands free system and all working fine.
    The old phone is still in the arm rest but with no power.
    Also Channel 2 .
    No DAB radio, but I think it did at one time as there is extra wiring in the boot at the electrical stack.
    Dave.
    A6 C6 one of the first . AUK engine .
  5. Re: ABS Unit
    #25
    Sep 2011
    Viewing page 10 of this Fiscon bluetooth install guide channel 12 needs to be set to 2, after setting it so reboot MMI and clear the DTC in module 07 and see if it returns.
    To remove DAB, channel 2 would just be 02. You would also need to adjust settings in CAN Gateway, assuming it has DAB coded into it. I'm assuming you can't access that module as log states:-
    Address 19: CAN Gateway
    Cannot be reached
  6. Re: ABS Unit
    #26
    Feb 2012
    folkestone.uk
    Hi Gup.
    Just got around to looking at this .
    Something is defiantly off with channel 1.
    I have . Ambient lighting 00002
    Acoustic parking rear 00004
    Rain sensor 00256
    steering wheel 04096
    Total 4358
    Should I change to this total?
    Re done scan, don't know why it did't before see below
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 08008044260059
    Coding: ECFE73C41B3104
    Shop #: WSC 02325 785 00200
    VCID: 275B8D5B962222190F5-8072
    1 Fault Found
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Dave.
    A6 C6 one of the first. AUK auto
  7. Re: ABS Unit
    #27
    Nov 2012
    Somerset UK
    Intrigued as to what the last posts have to do with an ABS unit
  8. Re: ABS Unit
    #28
    Sep 2011
    Quote Originally Posted by daveplyjeep View Post
    Yes mate I would change the coding to reflect what the car has. Did changing channel 12 data value to 2 get rid of the DTC code 0003 in module 07?
    1 Fault Found
    If you now have access to this module you can use the "Installation list" button to tick/untick options relating to car (ie DAB, etc), rather than doing changes via the coding/adaption section for this module.
    Quote Originally Posted by MarkTM View Post
    Post 16 Dave highlighted he had a DTC code 0003. I could not make out which module Dave was having this DTC in, so I asked for section of log and in post 18 we see it's in module 07. AFAIK this coding issue should not lead to the issue Dave is having as stated in post 3. Post 20 has DTC codes in ABS module:-
    Code:
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 A    HW: 4F0 614 517 A
       Component: ESP8 quattro    H03 0330
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004511
       Shop #: WSC 02327 785 00200
       VCID: 224D9C4FFD00C73158B-8077
    2 Faults Found
    00526 - Brake Light Switch (F)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 201
                        Mileage: 254113 km
                        Time Indication: 0
                        Date: 2016.11.25
                        Time: 14:56:33
                 Freeze Frame:
                        Hex Value: 0x0200
                        Hex Value: 0x4082
                        Hex Value: 0x0204
                        Hex Value: 0x00AD
                        Hex Value: 0x00FF
    00778 - Steering Angle Sensor (G85)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 201
                        Mileage: 254115 km
                        Time Indication: 0
                        Date: 2016.11.25
                        Time: 15:16:25
                 Freeze Frame:
                        Hex Value: 0x4280
                        Hex Value: 0x4002
                        Hex Value: 0x123B
                        Hex Value: 0x00AC
                        Hex Value: 0x00FF
    Which are unresolved so far AFAIK.
  9. Re: ABS Unit
    #29
    Feb 2012
    folkestone.uk
    Hi all.
    And so it goes on.
    I have now changed the ABS unit and coded it.
    Below is the latest scan.
    Sunday,04,December,2016,12:52:58:53046
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Ross-Tech: Home
    VIN: WAUZZZ4F35N010402 License Plate: 4/12/16/111
    Mileage: 254650km-158232mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 72 76
    VIN: Mileage: 254650km-158232miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F0 910 115 HW: 4F0 907 115
    Component: 3.2l V6 FSI G 0040
    Revision: --H14--- Serial number:
    Coding: 01050003190F0120
    VCID: 5BB3E1AB9AEAB6F95BD-800E
    3 Faults Found
    17981 - Left Engine Mount Solenoid Valve (N144)
    P1573 - 000 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 178
    Mileage: 254644 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 14:02:27
    Freeze Frame:
    RPM: 2272 /min
    Mass Air / Rev.: 463.3 mg/str
    Temperature: 85.5°C
    Part Throttle
    Load: 71.0 %
    Bin. Bits: 00110010
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 000 -
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 179
    Mileage: 254657 km
    Time Indication: 0
    Date: 2016.12.04
    Time: 12:06:54
    Freeze Frame:
    RPM: 608 /min
    Mass Air / Rev.: 185.3 mg/str
    Temperature: 82.5°C
    Idle
    Load: 33.3 %
    Speed: 0.0 km/h
    17547 - Fuel Trim: Bank 2 (Add)
    P1139 - 000 - System too Rich - Intermittent
    Freeze Frame:
    Fault Status: 00010010
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 254657 km
    Time Indication: 0
    Date: 2016.12.04
    Time: 12:06:54
    Freeze Frame:
    RPM: 608 /min
    Temperature: 82.5°C
    Idle
    Time: 2176.0 s
    Bin. Bits: 00000000
    Readiness: 0010 0001
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 157 E HW: 09L 927 156
    Component: AG6 09L 3.2 FSI RdW 0060
    Revision: 00000001 Serial number: 0019902
    Coding: 0000001
    VCID: 2645805F91283B11343-8073
    No fault code found.
    Coding: 0004511
    Shop #: WSC 02335 785 00200
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 254657 km
    Time Indication: 0
    Date: 2016.12.04
    Time: 12:45:52
    Freeze Frame:
    Hex Value: 0x0240
    Hex Value: 0x4082
    Hex Value: 0x0000
    Hex Value: 0x00AE
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: None
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0220
    Revision: 31050601 Serial number: 10600300022365
    Coding: 0000023
    Shop #: WSC 00613 210 85940
    VCID: 63C3D94BA29A8E3913D-8036
    Subsystem 1 - Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H43 0060
    Subsystem 2 - Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H25 0070
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H43 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350DP047507198
    Coding: 0000002
    VCID: 25478753EC2E30093D9-8070
    Subsystem 1 - Part No: 4F0 910 609
    Component: Bedienteil MMIC6H03 0870
    Subsystem 2 - Serial number: 00000000009355
    Subsystem 3 - Serial number: 0126.04.040000000100010105ÿ
    Subsystem 4 - Serial number: 010105ÿ
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 C
    Component: KLIMABETAETIGUNGH11 0060
    Revision: 00000021 Serial number: 00000000018232
    Coding: 0533510
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    VCID: 66C5C05F51A8FB11F43-8033
    Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0040
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H43 0470
    Revision: 00000000 Serial number: AUZ5ZBD4001453
    Shop #: WSC 00000 000 00000
    VCID: 1C31A2B7DF64F1C1927-8049
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 G HW: 4F0 959 655
    Component: 20 AIRBAG AUDI8RH24 0110
    Revision: 07H24000 Serial number: 00358D05BBV1
    Coding: 0012848
    Shop #: WSC 00613 210 88222
    VCID: 2B53716B8ACA0679EBD-807E
    Subsystem 1 - Serial number: 6332CSME022D4244Z
    Subsystem 2 - Serial number: 6342CSME025D2516$
    Subsystem 3 - Serial number: 6351HSME022D48501
    Subsystem 4 - Serial number: 6361HSME02350570X
    Subsystem 5 - Serial number: 6371VSME024C10305
    Subsystem 6 - Serial number: 6381VSME02390F6DW
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H06 0130
    Revision: 00H06000 Serial number: 90026041270143
    Coding: 0102141
    Shop #: WSC 02323 785 00200
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 G
    Component: KOMBIINSTR. M73 H07 0630
    Revision: 00600000 Serial number: 49E30U554
    Coding: 0001443
    Shop #: WSC 00011 888 96745
    VCID: 1E35A8BFC978E3D17C3-804B
    Cannot be reached
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
    Component: MNS ECE H43 1060
    Revision: 00000000 Serial number: 353EN047518361
    VCID: 3B73412B7AAA96F97BD-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: 5
    Coding: 0017018
    VCID: 295F8B6380361469191-807C
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H14 0090
    Revision: 00900014 Serial number: 01000193600000
    Coding: 0140787
    VCID: 2C5172778FC40141E27-8079
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0010
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 11S00001 Serial number: 01604040011286
    Coding: 0000007
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H07 0040
    Revision: Serial number: 00000000009729
    Coding: 0001104
    VCID: 5EB5E8BF89F8A3D13C3-800B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: t“
    Coding: 0017018
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB C63C0040 H03 0040
    Revision: C63C0040
    Coding: 0005021
    1 Fault Found
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 220
    Mileage: 254656 km
    Time Indication: 0
    Date: 2016.12.04
    Time: 12:46:17
    Freeze Frame:
    Voltage: 12.73 V
    Count: 236
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 A
    Component: Dynamische LWR H01 0010
    Coding: 0000003
    VCID: 38795E274B9CBDE196F-806D
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0630
    Revision: 00000000 Serial number: 352EN047522772
    Coding: 0000001
    VCID: 316F6303A8E66CA9D11-8064
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H11 0490
    Revision: 00000000 Serial number: 00000000011099
    Shop #: WSC 00613 210 08658
    VCID: 2343994BE21ACE3953D-8076
    Subsystem 1 - Part No: 4F0 915 105 C
    Component: von VA0 1404290003
    Coding: 344630393135313035432056413031343034323930303033
    Shop #: WSC 00000 640 00290
    1 Fault Found
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 254656 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 22:43:17
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H09 0010
    Coding: 0016426
    VCID: 2A5D746F85301F7110B-807F
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H09 0010
    Coding: 0016426
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0020
    Revision: --.--.-- Serial number: 11730412404917
    Coding: 0001006
    VCID: 61CFD343B8869C29011-8034
    4 Faults Found
    01548 - Sensor for Parking Aid; Rear Right (G206)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 254649 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 14:18:23
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 254649 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 14:18:23
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 254649 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 14:18:23
    02070 - Rear Parking Aid Sensors
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 254640 km
    Time Indication: 0
    Date: 2016.12.03
    Time: 13:47:55
    End-------------------------(Elapsed Time: 04:11)--------------------------
    Plus found this after going into M. Blocks in 19.
    VIN: License Plate: 4/12/16/111
    Address 19: CAN Gateway (4F0 910 468 A)
    12:55:34 Group 001: Line Status
    Data for Wake-Up Line
    Group 001 CAN-Comfort Static
    Not CAN-Infotainment Static
    Available CAN-Powertrain Static
    12:55:34 Group 002
    180.0 Unlearn Counter
    1 Ring Break Diagnostic Wire
    12:55:34 Group 003
    180.0
    Thanks for looking.
    Dave
  10. Re: ABS Unit
    #30
    Jul 2013
    77 Post(s)
    Your fault is a defective brake light switch or a wiring issue with the brake light switch.
    The Switch is not for the brake lights only.
    This was pointed out in Post 28.
    The ABS unit that you took off maybe OK.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  1. faulty abs unit repaired, now new brake issue pulsing pedal
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-09-2012, 07:48 PM
  2. abs module removal, must I remove the whole abs unit?
    By Bobby101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-11-2010, 11:38 AM
  3. Why new ABS Unit if no ABS warning light?
    By kaygolf in forum Golf MK4 - 1999 - 2004
    Last Post: 23-01-2009, 12:55 AM
  4. Question Suspected ABS issue
    By cookie_vwpolo97 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2008, 09:48 PM
  5. Suspected ABS problem
    By Andy73 in forum Audi A3 - Archive Topics
    Last Post: 04-11-2007, 12:01 AM
