Thread: Suspected ABS Unit faulty?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Suspected ABS Unit faulty?
    Feb 2012
    folkestone.uk
    Hi All.
    Could anyone tell me.
    Are the ABS units prone to packing up on this model.
    Thanks in advance for all info received
    Dave
  2. Re: ABS Unit
    Nov 2012
    Somerset UK
    Not read of any issues on this forum in 4yrs.
    What issue do you have?
  3. Re: ABS Unit
    Feb 2012
    folkestone.uk
    Hi Mark.
    Sorry for not getting back before.
    Driving along all good under normal braking. If you brake a bit harder say at a junction.
    First the ESP and the ABS lights come on then the Amber handbrake light. The first 2 lights stay on and the Handbrake light will come on with alarm at 15 mph each time.
    Stop and restart and all good until you start above again.
    Fault codes indicate wiring or abs unit.
    My thinking is. If it was wiring it would happen no matter how you braked
    I have changed speed sensors. rear pads and checked an old wiring fault on handbrake. Also done basic settings reset and function reset.
    Regards
    Dave
  4. Re: ABS Unit
    Jul 2013
    77 Post(s)
    have you read the fault code?
    You need this before you waste anymore money.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  5. Re: ABS Unit
    Feb 2012
    folkestone.uk
    Hi.
    Could someone please tell me how to clear the DTCs supported codes in the "Control Head" and the ABS controller.
    When I run a scan I am told to "Please check DTC Memory of ABS Controller"
    Dave
  6. Re: ABS Unit
    Feb 2009
    West Yorkshire
    10 Post(s)
    Check it then. Go into that module and read codes then clear. Sometimes you have to clear each module individually.
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  7. Re: ABS Unit
    Feb 2012
    folkestone.uk
    Hi.
    That's the problem I'm having. I have 34 DTCs stored ,tried to deleat one at a time but won't let me.
    Dave
  8. Re: ABS Unit
    Jul 2013
    77 Post(s)
    Try the Hidden Menu
    In car then qualified DTC's and then look for the ABS module and the Control head and then clear the DTC in there.
    Dan
  9. Re: ABS Unit
    Feb 2012
    folkestone.uk
    Hi all again.
    The hidden menu looked scary.
    Now trying something new.
    Can anyone give me a BEM code for my battery please..Its a Varta, H3 12v 100Ah 830A.
    Or one that would do.
    Dave
  10. Re: ABS Unit
    Nov 2012
    Somerset UK
    If you're changing like for like spec then a new code isn't needed.
    Or have you deleted the current one/fitted a different spec battery.
    In the case of mine with Gups advice I simply made one up!
  1. faulty abs unit repaired, now new brake issue pulsing pedal
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-09-2012, 07:48 PM
  2. abs module removal, must I remove the whole abs unit?
    By Bobby101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-11-2010, 11:38 AM
  3. Why new ABS Unit if no ABS warning light?
    By kaygolf in forum Golf MK4 - 1999 - 2004
    Last Post: 23-01-2009, 12:55 AM
  4. Question Suspected ABS issue
    By cookie_vwpolo97 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2008, 09:48 PM
  5. Suspected ABS problem
    By Andy73 in forum Audi A3 - Archive Topics
    Last Post: 04-11-2007, 12:01 AM
