Thread: poor idle
Results 1 to 10 of 10
  1. poor idle
    Sep 2007
    ok i have just replaced the throttle body on my mk4 golf 1.4 16v e 1998 now runs alot better,but if i rev it just a little it wil hunt but if i rev it up to 2k it is ok? anyone any ideas? also if i hold the revs at 2k it wil sound like it is missfiring like popping? also now and again my temp sensor stops working but then it wil work then stop again could this be the problem?can anyone help please thankyou
  2. Re: poor idle
    coolant temp being irratic will definatly not help your situation, probably a new sensor required there, as for your other faults, when throttle bodys are fitted they need to have there basic setting adapted usually by the vw diagnostics machine or a vag-com will do it, this will allow the engine control unit to know where it's idle is!!!
  3. Re: poor idle
    Sep 2007
    ok thanks i will get a new temp sensor,as for vag com i have just downloaded 704 from ross tech but dont have a cable as of yet,will this fix my problem?
  4. Re: poor idle
    Aug 2007
    Northern Ireland
    Your new temp sensor could well cure the problem.
    52 plate Golf GT TDi
  5. Re: poor idle
    134 Post(s)
    2018 Post(s)
    When you get your VAG-COM cable (it will need to be a registered version) you need to read for faults, deal with them and clear the codes. Then when there are no codes stored, get the engine hot. Turn off and turn the ignition back on. Go into adaptation 10 and group 00, read and save and click "yes" when given the option. Come back out of adaptation and go into basic settings 04, sub group 098 and wait whilst the throttle body is adapted and the fourth block in the display says “ADP OK”. Exit basic settings after at least 15 seconds, exit engine group and turn the ignition off for 15 seconds.
  6. Re: poor idle
    Sep 2007
    ok thanks just bought a cable of ebay will this do the job??
  7. Re: poor idle
    134 Post(s)
    2018 Post(s)
    Doubt it, those cables usually won't let you into Basic settings 04 and adaptation 10.
  8. Re: poor idle
    Sep 2007
    ah dammit im readin all kinds of things off the internet saying they work etc
  9. Re: poor idle
    134 Post(s)
    2018 Post(s)
    Why don't you buy an approved cable? After all, Ross Tec won't keep developing the software for free if no one buys their cables.
  10. Re: poor idle
    Quote Originally Posted by lee07 View Post
    Just wondering if you got the new temp sensor & if it worked or not? I'm having similar problems, only idles erratically when the engine is warm, cleaned throttle body too.
  1. Poor idle on tdi when cold
    By tezray in forum Archive posts
    Last Post: 15-09-2007, 03:20 PM
  2. 2.5 v6 tdi very poor mpg?
    By phil18_1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2007, 03:50 PM
  3. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  4. TDI 130 Poor MPG
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2007, 12:27 PM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
