Thread: Removing front door cards? HELP
  1. Removing front door cards? HELP
    Nov 2016
    Ireland
    Hi all,
    First time Audi owner and first post here so forgive me if this has already been asked / answered.
    Bought an A6 SE Ultra a week ago, 2014 in white. Loving the car so decided to upgrade all interior bulbs to LEDs. Did the maps lights x 4,dome light,gloove box, boot etc and then removed the puddle lights (only on front doors in this spec). Now I cannot get sufficient slack on the wiring within the door to allow me plug the light fittings back in !!!!!!!!
    The only solution I see isto remove the doorcards and either generate the necessary slack or plug the light back in with the cards off. I can find plenty of demos on youtubeto remove cards on C6 but haven't been able to find anything C7 related. Any body do this and can you instruct / post pics please?
    Do I need torx screwdrivers as I currently don't own any but see them mentioned quite a bit in relation to Audis.
    Cheers in advance
  2. Re: Removing front door cards? HELP
    Aug 2016
    Veldegem - Belgium
    You first need to remove the 3 torx screws. You can pull of the door trim easily but be careful not to crack it
    After that you first need to release a clip who's behind the panel (see picture). Afther that you can pull around the panel to take it off.
    Hope this helps you.
    === My Ride: Audi A6 C7 Saloon - Oolong Grey ===
    === My Blog: Maxcarblog.com ===
  3. Re: Removing front door cards? HELP
    Nov 2016
    Ireland
    Thank you kind sir for the prompt reply.............. that's a job fortomorrow
    Now any idea how to fix a dodgy spacebar
  4. Re: Removing front door cards? HELP
    Nov 2016
    Ireland
    Actually Los Cuentos could I trouble you for the same information on the rear doorcards.......... the dampening mechanism on the ashtray in the rear door handle needs attention, something slightly askew
  1. Has anyone removed their front door cards?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2010, 11:39 PM
  2. Help!! - Removing door cards
    By A3Leigh in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-07-2009, 09:42 PM
  3. Removing seats, door cards and other interior trim
    By nebw in forum Golf MK6 - 2009 - 2013
    Last Post: 15-05-2009, 02:26 PM
  4. Polo 3-door, 1998, removing front door panel
    By mrex in forum Polo - Derby - Lupo - Fox
    Last Post: 13-08-2008, 08:14 PM
