Thread: S4 2003 central chassis vibration when loaded up
  1. S4 2003 central chassis vibration when loaded up
    Feb 2015
    Pool Cornwall
    Hi Guys,
    Recently had her in for new prop shaft; hoping that would cure bad shaking and vibration under hard acceleration.
    Shaft was replaced, but the vibration remained, albeit lessened.
    If it wasn't totally the shaft being the problem, what else could it be?
    Any answers would be gratefully received.
    Thank you.
    Audi S4 4.2 V8 2003 144,000 miles
  2. Re: S4 2003 central chassis vibration when loaded up
    Pembrokeshire
    22 Post(s)
    one of the driveshafts maybe, or clutch. i would have expected a rear diff bearing would have been spotted when fitting the prop. what frequency is the vibration. is it wheel speed, i.e once per revolution of a wheel so wheel, wheel bearing or driveshafts, or is it faster, like prop speed, or does it alter with which gear you are in or just with roadspeed.
  3. Re: S4 2003 central chassis vibration when loaded up
    Feb 2015
    Pool Cornwall
    Hi zollaf,
    Thank you for replying so quickly.
    She had a new clutch earlier on this year. Garage said that they had looked at the rear diff, but that was ok. They did put in a new bush in the rear... something or other, which was worn, but again, to no avail.
    New wheel bearings this year. It's more prop speed. When loading her up, vibrations run centrally down the chassis. Changing gears doesn't alter vibration. Driving at a constant speed is fine, but when accelerating, the vibration is felt.
  4. Re: S4 2003 central chassis vibration when loaded up
    Pembrokeshire
    22 Post(s)
    all the signs of prop bearing. only other likely culprit could be the diff bearing i spose.. or gearbox..
  5. Re: S4 2003 central chassis vibration when loaded up
    Feb 2015
    Pool Cornwall
    prop bearing would be covered with the new prop, I hope...
    I'll give the guys a couple more days, if nothing happens, I'll get her back and then perhaps try to sell her 'as is'.
    Gotta sleep now, will log on again tomorrow.
    Thanks for all your help so far mate,
  1. Replies: 1
    Last Post: 21-07-2015, 09:06 AM
  2. 2003 A4 1.9 130 vibration at idle
    By A7788 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-08-2012, 08:25 PM
  3. Question Loaded wheel
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2012, 07:12 AM
  4. Pictures loaded
    By gregpawley in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-02-2009, 11:28 PM
