Thread: Rear marker lights Audi S4 Quattro 2013
Results 1 to 10 of 13
  1. Rear marker lights Audi S4 Quattro 2013
    Nov 2016
    Barcelona
    We moved to Barcelona and they are asking us to change our rear marker lights from red to orange. I have looked everywhere and asked Audi how to replace the rear lights but they say no orange versions exist that they know of. Has anyone else had and/or solved this problem?
    It is a 2013 S4 Quattro, 245 kW, 333 HP, gas V6.
    Any help is much appreciated!
    Thanks,
    Adri
  2. Re: Rear marker lights Audi S4 Quattro 2013
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by puppadum View Post
    Thanks,
    Adri
    Only over the ocean is rear sidemarker bulb, is this usa version?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Rear marker lights Audi S4 Quattro 2013
    Nov 2016
    Barcelona
    Quote Originally Posted by Gunnark100 View Post
    Hi, Gunnark,
    This is the USA version and it has four rear LED lights that illuminate when you use the turn signals (so we have to replace 4 LED lights, two on right and two on left). I have taken a photo of them and included it below. Is that not standard on the German 2013 S4? Thank you very much!
  4. Re: Rear marker lights Audi S4 Quattro 2013
    Oct 2012
    Estonia
    64 Post(s)
    Ok, gotcha, you ment turnsignal. Yes you need to retrofit eu lights, im not sure are connectors same for facelift b8 eu vs usa, but if not, you need modify harness and coding. Audi probably mixed up with rear sidemarker. But if dealer will do the retrofit, they will charge huge amount of money, including new comfort module.
    So, if you care about money buy used eu lights, if connectors are different, you need to buy those also etc and costum coding of module 46. Sorry dont know local retrofitters in Spain.
    Euro rear light top bar are yellow for inner and outer lights and turnsignal blinking separate, not like in usa "red"!
  5. Re: Rear marker lights Audi S4 Quattro 2013
    Oct 2012
    Estonia
    64 Post(s)
    Thats euro:
    Audi A4 B8 8K 2008 with 2013 Facelift LED rear lights - YouTube
    Top bar yellow turn and below red brake, they function separate!
  6. Re: Rear marker lights Audi S4 Quattro 2013
    Cork
    Is it not just coding? I thought the white/clear strip was just for reverse in the US, where as in ROTW half is reverse and outer half is indicator? Just change outer bulb to Amber and recode.
    Am I wrong?
    Sent from my Brain via my Keyboard
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  7. Re: Rear marker lights Audi S4 Quattro 2013
    Oct 2012
    Estonia
    64 Post(s)
    Quote Originally Posted by defsix View Post
    Am I wrong?
    I am lost
    Where is second white light in FL lights which you can use for reverse after replacing outer bulb for yellow? The only bulb on those lights is reverse and white as far i know, all rest are leds and not white, OP can clarify for NA type. It was possible with halogen and preFL lights!
    "where as in ROTW half is reverse and outer half is indicator" - ROW facelift lights are using top bar inner+outer as turnsignal- its yellow! Nachrüstung a4 B8 Limousine Halogen auf Facelift LED Rückleuchten - YouTube
    If OP is happy with red or yellow reverse fine with me!
  8. Re: Rear marker lights Audi S4 Quattro 2013
    Cork
    I was looking at the picture attached above. The ones in the trunk would be white then the outer ones ones would be Amber. Are both of these LED? I thought was only brake / tail was led?
    | My Slipper |
  9. Re: Rear marker lights Audi S4 Quattro 2013
    Oct 2012
    Estonia
    64 Post(s)
    I have inside of inner light "clear/white bar" 3 or no idea how many red leds for fog, i dont belive NA sedan has there white leds inside, no bulb 100% if catalogue is correct!
  10. Re: Rear marker lights Audi S4 Quattro 2013
    Nov 2016
    Barcelona
    Thank you very much, Gunnark. I hope I am able to find someone who can install a used EU light, possibly change the electrical connection, and recode module 46. The Audi dealers here say there is nothing they can do, including rewiring the car.
  1. LED interior lights - allroad 2013
    By nick1212 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-04-2016, 09:10 AM
  2. Question Audi A3 2013+ Daytime running lights explained
    By Delboyd12 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 23-08-2015, 05:05 PM
  3. Audi S2 Quattro Coupe 610hp. Winter rally 2013 in Russia
    By Samael in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-06-2013, 09:29 PM
  4. A4 2.4 Avant Quattro TDI-Rear number plate lights
    By Dave Gee in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2009, 01:05 AM
  5. 2003 Audi A4-Brake Lights & Rear Lights
    By csheehy35 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 10:12 PM
