Thread: What is wrong with my Audi?
Results 1 to 9 of 9
  1. Exclamation What is wrong with my Audi?
    Oct 2016
    York
    Hi, I bought my second car 3 months ago, a 2002 Audi A4 1.9 tdi (130). The guy I bought it off sort of pulled the wool over my eyes as after I bought the car (after him giving a lengthy test drive as i was uninsured) i discovered it had a juddering problem (which he told me was the fuel filter) which is still unsolved to this day. Apart from this the car is absolutely sound, and drives fine, just judders very badly as you accelerate at low revs, and then further up the revs the juddering eases off.
    First i went to my local garage and had a diagnostics test. The mechanic took it for a test drive and diagnosed a misfire. So he plugged it vcds and it came up with no faults. Basically wasted £40 as he had no decent advice on what to do next apart from change the maf and map sensors which i had already done.
    Recently i have had my father who has access to vagcom plug his laptop in and look at the car for me. After driving up and down he said there is nothing abnormal showing up on the test results apart from the MAF sensor reading being high, which he says is to be expected as the car has had an EGR delete.
    The engine bay has been scrupulously checked for air leaks, both maf and map sensors changed, The car boosts well after about 2500 revs which suggests that the turbo is probably ok. Also a common problem is the lobes on the camshaft can wear, but this had been checked and is ok. A few people have told me it could be the DMF. Another thing i should state is the the car somtimes seem to reach its rev limit before it should ie only getting 40mph max out of 2nd gear
    Hoping sombody out there can shed some light on this problem
    Many Thanks, Guy
  2. Re: What is wrong with my Audi?
    Sep 2008
    chester
    17 Post(s)
    If your guy who diagnosed it as a misfire is right then I would be looking at the injector harness,could be the dmf also,is the judder transfering to the steering wheel?
  3. Re: What is wrong with my Audi?
    Oct 2016
    York
    Thanks, that will be my job tomorrow. The juddering doesn't transfer to the wheel, but saying that it is quite a violent judder and the gear stick goes crazy. I have heard about the injector wiring loom becoming damaged due to heat
  4. Re: What is wrong with my Audi?
    Sep 2008
    chester
    17 Post(s)
    That sounds too violent for a misfire,have a good look at all the mountings.
  5. Re: What is wrong with my Audi?
    Oct 2016
    York
    Sorry to keep posting back, took the rocker cover off and the shaft seemed fine with no major wearing on any of the lobes, and the visible wiring was also fine. fairly confident the problem is within the engine but did check the mounts and gave the engine a good rock but all seemed well. I think my next step is just to graph the results from the vcds and take to a specialist
  6. Re: What is wrong with my Audi?
    134 Post(s)
    2019 Post(s)
    If it has an illegal EGR delete I think the ECU must have been remapped to take away its ability to detect the modification, if I had it I would be putting it back to standard and fitting a new genuine AMM and taking it from there.
  7. Re: What is wrong with my Audi?
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by whoppadom View Post
    Looking at the injector loom won't give you any idea if it's not working correctly. Replace it.
    Ian
    A4 B6 Avant Nogaro Blue
  8. Re: What is wrong with my Audi?
    Oct 2016
    York
    The EGR is vaccum operated, would this still need mapping out the system?
  9. Re: What is wrong with my Audi?
    134 Post(s)
    2019 Post(s)
    on the PD the ECU checks the EGR operation so if it removed the MIL will come on.
  1. Question what's gone wrong now?
    By the lemster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2013, 04:02 PM
  2. 1998 audi a6 c5 something wrong i guess :(
    By qoro in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2012, 10:40 AM
  3. Have I done wrong
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2011, 10:54 AM
  4. Please Help Audi dealership keep giving me the wrong parts HELP !!
    By JAV1 in forum Audi A3 - Archive Topics
    Last Post: 30-01-2009, 03:22 AM
  5. What might go wrong?
    By WelshDan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-09-2007, 08:08 PM
