Thread: Eye watering fumes!!
Results 1 to 1 of 1
  1. Eye watering fumes!! - Oil in Diesel??
    Oct 2016
    derby
    Hi all,
    I have a passat 2007 2.0l TDI estate. it seems to have a rather dangerous fault.
    When idling, usually when cold but also on warming up the engine shakes very noticeably and sounds near on cutting out but also like diesel pinging i think, when this is happening the fumes out the exhaust will make your eyes burn and water they are that strong!
    I've looked through here but cant seem to see anything, I've just purchased vag com from genden and it reads the below fault, it only reads this after a drive. on idle for an hour today it does not register any faults at all. (this code is the same on 2 maf sensors as i went and got another today)
    the exhaust gases are deadly and i need to resolve this, the engine rocks and knocks when this is happening but it seems to purr when warm although the fumes are still strong.
    I've been reading and just spotted a post including the tandem pump, I've checked my Fuel filter and it is oily.... if there is oil in my diesel would it burn as a strong smell like my fumes are?
    any ideas please?
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 AS HW: 03G 906 018 AS
    Component: R4 2.0l PPD1.2 G 9971
    Revision: --H42--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00500 210 88180
    VCID: 76E26D510158E2F296-8022
    1 Fault Found:
    000258 - Mass Air Flow Sensor (G70)
    P0102 - 007 - Signal too Low - Intermittent
    Freeze Frame:
    Fault Status: 00000010
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 38
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 11.75 V
    Mass Air / Rev.: 850.2 mg/str
    Mass Air / Rev.: 0.0 mg/str
  1. fumes in 98 passat 1.8t
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2011, 06:29 PM
  2. Engine Fumes
    By StuS in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2010, 02:44 PM
  3. oil fumes
    By billy g in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2009, 12:43 PM
  4. Question Exhaust fumes
    By RichKi in forum Audi A3 - Archive Topics
    Last Post: 24-11-2008, 05:34 PM
  5. Please Help fumes in my car
    By bitzy in forum Polo - Derby - Lupo - Fox
    Last Post: 07-11-2008, 02:18 PM
