Thread: Mk4 V6 golf instrument cluster problems
  1. Mk4 V6 golf instrument cluster problems
    Oct 2016
    london
    Afternoon all,
    Having a bit of difficulty with the cluster on my v6 mk4 golf, the LCD packed up was planning on sending it off to cartronix or another firm,
    Pulled it and thought I'd have little look opened it up removed the Rev needle anti-clockwise and pulled the face etc to get a look and see if I cba to attempt it, decided otherwise before I sent it the Rev needle was out of alignment so I spun it back into place, and quickly tested it...
    And it wasn't working right. It gets stuck around at random points and hitting the limiter conks out at 6ish,
    Not only that the temp and fuel needles freeze and don't return back to the start,
    Just tried adjusting the Rev needle slightly, I read that it should only be adjusted anti clockwise so I spun it around and plugged it back in still not working, after some attempts however I did notice the temp/fuel needles dropped down quicker,
    Not sure if it's my constant removing of battery/ plugs at the back,
    At the moment it's worse, ive taken the cover off, and just flicked the temp and fuel needles back to start with the ignition off but with batt connected and now nothing works!
    Got a diagnostic machine and tried to flick gauges on half/ full nothing happened,
    All the wires are fine/ intact, all the lights are working, car starts up fine repeatedly no low battery,
    Any advice much appreciated,
    Wondering if it would be easier to just get another good set of clocks with a good lcd screen!
  2. Re: Mk4 V6 golf instrument cluster problems
    Pembrokeshire
    22 Post(s)
    i would stop messing and just send it off, tell them what you have also broken and hopefully it wont cost too much to put right.
  3. Re: Mk4 V6 golf instrument cluster problems
    Oct 2016
    london
    Yeah fair enough,
    Need to find out how much a new cluster would be atm im getting quotes for about £100 or so to repair, if a new ones not far off probably get that ive got vagcom so should be fine programming the new cluster and setting the mileage.
  1. Please Help Golf Mk5 Instrument CLuster Problems
    By baggyboy in forum Golf MK5 - 2004 - 2009
    Last Post: 13-04-2016, 03:33 PM
  2. Golf gt tdi 2004 swapping instrument cluster for a gti one
    By badayuni92 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2015, 11:10 PM
  3. Dash Board/Instrument Cluster Replacement problems
    By Clauuualc in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-05-2015, 01:23 PM
  4. Replies: 2
    Last Post: 10-08-2012, 09:33 AM
  5. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
