Thread: Coolant system renewal!
  1. Coolant system renewal!
    Aug 2007
    OK so the time has come I think to renew the coolant in my car.
    Problem kinda started when I saw that I had a coolant leak! One of the metal pipes in the cooling system has rusted through and is leaking coolant.
    I have bought a new pipe + some new seals from the local VW dealers. I intend to
    1. Drain the system,
    2. Flush the radiator out also
    3. Remove and replace faulty pipe and seals.
    4. Reassemble everything and refill with coolant
    The question I have is "How much coolant does a mk3 gti 8V take?" I cant seem to find that information anywhere? I think its G12 coolant I get and I mix it 50/50 with distilled water (does it have to be distilled? will bottled mineral water do instead?) Not sure about this part, but what is the total volume of coolant mix the car will take?
    Oh one last point! Er... Anyone know a good way to clean coolant marks from inside the engine bay?
    Alot of questions, I know
    Any help?
  2. Re: Coolant system renewal!
    134 Post(s)
    2019 Post(s)
    It is roughly a six litre system so as G12 comes in 1.5 litre bottles... I would recommend you use G12+.
  3. G12+!
    Aug 2007
    Cheers nice one crasher!
    G12+ you say? So what are the advantages of using "+" and not using?
  4. Re: Coolant system renewal!
    134 Post(s)
    2019 Post(s)
    G12+ mixes with anything if it has to whereas G12 won't mix with G11 and it is a "For Life" fill whereas G12 should be changed every two years. It is also more environmentally friendly.
  5. Re: Coolant system renewal!
    Aug 2007
    Very cool!
    Its G12+ for me then
    I suppose I can get distilled water from the dealership as well, Ill call into them on monday.
    Now I still have to figure out how to remove the coolant marks from the engine. It looks terrible at the moment, Pinky stains!
    Any tips on the best way to remove it? It seems eaten in like acid!
    Cheers anyway
  6. Re: Coolant system renewal!
    134 Post(s)
    2019 Post(s)
    It is evil to get off.
  7. Re: Coolant system renewal!
    Aug 2007
    Happy days!!!
    I got the use of a pit in my friends garage today. Removed all the hoses, flushed the radiator. I had some problems with removing the old metal pipe that had rusted through. The rubber pipes, did not want to come off there!
    Some hot water, a heat gun and alot of gental persuasion got them off and the rest was easy.
    Refitted everything and refilled the water + coolant (G12+) and all is happy days!
    I still have to scrub away the old G12 leakage marks but I'm happy with todays progress!
    Thanks again crasher
  1. Coolant and Brake fluid renewal
    By djheath in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2008, 05:27 PM
  2. CV Joint Gaiter/Boot Renewal
    By Gary537 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-10-2007, 11:32 AM
  3. Audi 90 2.3e wishbone bush renewal
    By m4xmw in forum 80 - 90
    Last Post: 24-05-2007, 08:08 PM
  4. storage system
    By mavlyud in forum Chat - Completely Off Topic
    Last Post: 24-02-2007, 02:01 AM
  5. Harddisk / MP3 in car system?
    By hscbaj in forum Passat - Archive Topics
    Last Post: 12-07-2006, 10:57 AM
