Thread: Is the bottom pulley failing common?
Results 1 to 10 of 13
  1. Is the bottom pulley failing common?
    recently rescued a k plate aaz engined golf from being scrapped. the cam belt had shredded but not broken and the timing had slipped. ii have fitted cam belt kit and re timed it runs fine but i noticed odd wear to the inside of the bottom pulley where it fits the sprocket and it wobbles a good'un when running, the sprocket has been inspected and is fine so i'm thinking there may be a problem with the pulley? is this common can anyone tell me? or is there likely another problem? any help gratiously recieved. thanks.
  2. Re: Is the bottom pulley failing common?
    well there is a corrado 16v scrap engine at work. the pulleys look the same. guess i just swap em and try it?
  3. Re: Is the bottom pulley failing common?
    Quote Originally Posted by aaz f7r View Post
    Did you change the bottom pulley before? Belts dont just shread - something has to happen to them... normally in the way of a dodgy pulley!
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  4. Re: Is the bottom pulley failing common?
    135 Post(s)
    2036 Post(s)
    The face of the crank will need to be re-cut as the pulley coming loose severely damages the end of the crank and a new pulley will never run straight. There is a special tool for re-cutting the face of the crank in situ. This is a very common problem on the AAZ and many others, petrol and diesel. The KR/9A bottom pulley is different to that for an AAZ which is part number 028 105 263 C @ £24.62 and you MUST replace the bolt which is N 905 771 01 @ £1.61. The bolt MUST be tightened up to 90Nm plus an additional 90 degrees and the crank held solid using VW tool 3099. Sorry about the poor picture, I wish I could get Photo Bucket to work for me!
  5. Re: Is the bottom pulley failing common?
    May 2007
    knee deep in clunge
    14 Post(s)
    crasher your reading those part numbers again,you have got a problem,you will go blind
  6. Re: Is the bottom pulley failing common?
    135 Post(s)
    2036 Post(s)
    Funnily enough, I have just started using glasses for the first time, I must stop before it is too late!
  7. Re: Is the bottom pulley failing common?
    May 2007
    knee deep in clunge
    14 Post(s)
    i only see p0 fault codes and wiring diagrams through my eyes
  8. Re: Is the bottom pulley failing common?
    the crank pulleys fine its the one that bolts onto it with the rubber bit that isn't running true.
  9. Re: Is the bottom pulley failing common?
    135 Post(s)
    2036 Post(s)
    That runs out of true due to the one it is bolted to being loose and having slipped back. Take the toothed belt pulley off and the crank will be hammered. The Poly V belt dampers don't fail. It happened to my AAZ and many others I have seen but not just the AAZ although it does seem to happen to most of them.
  10. Re: Is the bottom pulley failing common?
    i took it off n thoroughly inspected it. its fine. its baffling me.
  1. Air Mass Meter repeatedly failing
    By Daveymaclad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-10-2007, 12:29 AM
  2. A6 Air con failing
    By John540 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-05-2007, 09:08 PM
  3. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
  4. VW Polo Dashboard failing
    By polo9n in forum Polo - Derby - Lupo - Fox
    Last Post: 04-01-2007, 10:37 AM
  5. MAF keeps failing?
    By cookie_monster in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2006, 12:48 PM
