Thread: Bushes worn on lower shocks.
  1. Bushes worn on lower shocks.
    Jan 2010
    southport
    I've noticed today that the shocks bottom bushes have small cracks in them. As i have Mag Ride shocks, can the bushes just be pressed out and replaced?
    If so can anyone give p/N an price.
    Thanks.
    Graham
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  2. Re: Bushes worn on lower shocks.
    134 Post(s)
    2001 Post(s)
    Rears obviously.... You can't buy the bushes anywhere. The dampers were revised in mid 2008 (typically part number 8J0 513 025 F) and so require some conversion parts plus fixings and probably bump stops so it works out at around £330 a side in parts and a couple of hours labour.
    2 1 0
  3. Re: Bushes worn on lower shocks.
    Jan 2010
    southport
    Thanks for that Crasher.
    Thats alot cheaper han buying New Mag ride dampers tho.
    Why did Audi change them?
  4. Re: Bushes worn on lower shocks.
    134 Post(s)
    2001 Post(s)
    That is for new mag ride dampers, the revised versions, VAG are always changing things, there is a note in the TPI's about leaking dampers but that's all.
  1. Wear on inside of rear tyres - worn bushes?
    By Straight6DOHC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-06-2014, 08:41 AM
  2. Replies: 4
    Last Post: 29-01-2013, 07:11 PM
  3. Question Worn suspension bushes + MOT
    By swsteve in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2010, 09:10 PM
  4. Suspension Front lower arms worn
    By Sparky69 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2009, 10:41 AM
  5. rear bushes worn
    By johner in forum Bora - 1998 - 2005
    Last Post: 06-08-2009, 07:42 PM
