Thread: fault code
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
  1. Re: fault code
    #31
    Aug 2014
    uk
    aye, has to be worth a try. the only thing that gets me, is the fault code appeared and replaced the original fault code after the first throttle body was cleaned, same code two throttle bodys... ive seen on other forums wiring and ecu being the worst case relating to 00282 - Throttle Position Actuator(V60)
    26-00 - Output Open
    if it was in your workshop, youd try another throttle body first?
  2. Re: fault code
    #32
    133 Post(s)
    1991 Post(s)
    From the incorrect idle switch reading I would have fitted an OE throttle body or refused to go any further. I have reached the point of refusing to use any second hand parts of any description, over the last 30 odd years they have cost me so much time and stress that it is no longer worth it.
  3. Re: fault code
    #33
    Aug 2014
    uk
    breakers sent out another TB, another with the same error message for adaptation. i know its old parts, but the same problem with 3 TB? has to be wiring or ecu?
  4. Re: fault code
    #34
    133 Post(s)
    1991 Post(s)
    If the cable is detached and the TB spotlessly clean I can't see what else 00282 can be. We need to delve deeper into the wiring so I need the cars build month so PM me your reg.
  5. Re: fault code
    #35
    Aug 2014
    uk
    With some help found the fault. Is the plug or wiring to the throttle body. Someone's tried to repair it before
  6. Re: fault code
    #36
    133 Post(s)
    1991 Post(s)
    You may need a new plug, terminals or terminal extraction tool.
  7. Re: fault code
    #37
    133 Post(s)
    1991 Post(s)
    It was built 05/05/99, the plug you need is VW part number 4A0 973 714 G which is £9 and the repair wires you need are 0.5-mm, 000 979 019 EA @ £5.04 each (they are double ended and you would need 3) and 1.0-mm, 000 979 131 EA (you need 1) @ £3.65, that is if all the wires need repairing, using a terminal extractor you could save some.
    1 1 0
  8. Re: fault code
    #38
    Aug 2014
    uk
    the wiring was changed, i removed a plug and part of the wirining harness and soldered the replacement one on, it has helped, car is running better...
    sometimes it cuts out when slowing down and turning left, any ideas ?
  9. Re: fault code
    #39
    133 Post(s)
    1991 Post(s)
    Was the throttle body matched to the engine in Basic Settings 098? Are there a fault codes stored? A common failure is the power steering pressure switch, you have to watch it in measuring blocks as it does not always come up as a fault code.
  1. Dreaded ESP Fault DIS warning and G201 fault code
    By Daz6546 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2015, 01:53 PM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
