Thread: fault code
Results 11 to 20 of 39
  1. Re: fault code
    133 Post(s)
    1987 Post(s)
    Bridge contacts 3 and 7 of the plug to the TB, Measuring Blocks 098 Zone 3 MUST change to "Idling"
  2. Re: fault code
    Aug 2014
    uk
    with 3 and 7 bridged it changes to idle, still has error in the field after idle
  3. Re: fault code
    May 2008
    Crasher, are you able to look at a PM I sent you.
    Sorry to hijack
  4. Re: fault code
    133 Post(s)
    1987 Post(s)
    Quote Originally Posted by joe67 View Post
    You have a faulty throttle body.
  5. Re: fault code
    Aug 2014
    uk
    OK mate, really appreciate the help once again. Will update thread when replacement arrives. Cheers
  6. Re: fault code
    Aug 2014
    uk
    replaced the TB today, its changed to idle now without bridging pins, not closed throttle, disconnect cable again?? it still says error in the last field, that will be why i cant complete the alignment?
    edit: fault codes
    00282 - Throttle Position Actuator (V60)
    26-00 - Output Open
    and
    the basic settings one keep returning
  7. Re: fault code
    #17
    133 Post(s)
    1987 Post(s)
    Do it with the cable off. Was this TB new or used? What is the part number?
  8. Re: fault code
    #18
    Aug 2014
    uk
    tryied it with the cable off, i did see it change to adp ok for a second and to error when i switched from measuring blocks to basic settings.. its from a breaker,
    edit: 030 133 064 F
  9. Re: fault code
    #19
    133 Post(s)
    1987 Post(s)
    That is the correct TB number.
    Is your copy of VCDS Lite registered?
    By your ECU number it looks like your car is a 2000 model year version.
  10. Re: fault code
    #20
    Aug 2014
    uk
    Yes its a registered version on vcds lite. Just matched the part number, glad its the correct one. It does seem alittle better new the new TB, though it stuggles to idle.
  1. Dreaded ESP Fault DIS warning and G201 fault code
    By Daz6546 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-09-2015, 01:53 PM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
