Thread: Diff Lock Control
  1. Diff Lock Control
    Sep 2007
    I have recently acquired a 1989 90 20V quattro to replace my 91 80 2.0E.The diff lock switch by the handbrake illuminates with ignition but when I press it nothing seems to happen, no additional light comes on (should one come on?) and the drive feel stays the same,help please
  2. Re: Diff Lock Control
    Gwent
    It should come on at speeds up to 15mph, at 15mph it should disengage. a green? led should light up when it is active. It is driven by vacuum to an actuator on the diff, maybe a wiring problem or a vacuum leak?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Diff Lock Control
    Sep 2007
    Thank you,scotty33.Is the green light by the handbrake or on the dashboard?
  4. Re: Diff Lock Control
    Gwent
    It is on the 'drivetrain schematic' by the handbrake. If I remember right, the led is where the rear diff would be. Hope you enjoy your new car!
  5. Re: Diff Lock Control
    Sep 2007
    Thanks scotty 33.The car is a fantastic drive,superb looks but I've made a lot of visits to petrol stations so far!!
  6. Re: Diff Lock Control
    paul20v Guest
    hi
    when it works it also imobilises the abs which is indicated by the dash light coming on
    faults are normally sticky actuater on diff or vac pipe split quite often in the engine bay it comes from the manifold behind the battery and into the bulk head hope this helps
  7. Re: Diff Lock Control
    Sep 2007
    Thanks paul20v
  1. Is the S3 and 4Motion rear diff interchangeable?
    By Mokeylock in forum Archive posts
    Last Post: 28-02-2007, 01:46 PM
  2. S3 rear diff on 4Motion Golf - help needed
    By Mokeylock in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-02-2007, 01:26 PM
  3. 1986 Ur-Quattro coupe rear diff
    By adey26 in forum Archive posts
    Last Post: 05-06-2006, 10:05 AM
