Thread: headlight range control position wayout
  1. headlight range control position wayout
    May 2007
    Driving home at night and getting flashed by cars on the opposite side of road so I pulled over into a layby and checked lights
    Yep the lights were self leveling but not at the right level, they were pointing upwards. When I got home I checked the settings for exterior lighting all were correct. When the headlamps are turned on at the ignition they both move up and down then settle but are set way to high.
    Is this a sensor failure on rear or front suspension or braket failure or something else ? Has any one else had this problem
    Audi A4 2011 2ltr .....thanks.
  2. Re: headlight range control position wayout
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Yes it could be a level sensor on either the front or rear , usually on n/s of car. could be a worn ball joint on the arm or an electrical fault.
    Alan.
    VW T6 150 DSG Camper £££
  1. Headlight range control defective
    By newa4b8sline in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-05-2013, 08:17 PM
  2. Headlight Range Control Warning
    By kid-jensen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2011, 10:18 AM
  3. Question headlight range control
    By rhodie03 in forum Bora - 1998 - 2005
    Last Post: 06-11-2010, 01:56 PM
  4. Sharan headlight range control motor
    By soup_dragon in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2009, 09:10 AM
  5. headlight range control
    By rodaire in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2008, 02:20 PM
