Thread: Audi A4 1.9 TDI engine brb not starting no errors
Results 1 to 10 of 11
  1. Audi A4 1.9 TDI engine brb not starting no errors
    Oct 2016
    Poland
    Hello everyone,
    I have problem with Audi a4 1.9 TDI 2006, engine brb. Car doesn`t start and there are no errors on the computer. I think that I checked everything - pd, distribution, compression, mass, fuel supply, booster pump, high pressure pump.
    Does enyone has the same problem?
    Thank you for your help.
  2. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Jul 2007
    glasgow
    35 Post(s)
    tow it to see if it starts or bump start it
    might be starter not turning car over fast enough, looking at around 280 rpm for starter to allow fuel to run
  3. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Oct 2016
    Poland
    Quote Originally Posted by niall campbell View Post
    Thanks for answer. I tried to tow the car but it doesnt want to start either. Problem with that car is that the injections dont pump fuel but i cant find the reason why this is happening.
  4. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Jul 2007
    glasgow
    35 Post(s)
    is the cambelt still intact ?
    do you think the camshaft sensor is ok and cambelt is aligned correctly ?
    changed the fuel filter etc ?
    think its time for a vcds scan
  5. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Oct 2016
    Poland
    Cambelt is ok and correct.
    I changed fuel filter, regulator valve on the filter, tandem pump, and pd.
    The compressing is ok.
    vcds:
    No trouble code...
    I have seen the engine speed and cam.
    all temperatures are ok.
    All the earth and plus to the engine module was checked.
  6. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Jul 2007
    glasgow
    35 Post(s)
    Have you got fuel at the injector when cranking over ?
  7. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Oct 2016
    Poland
    Sorry for timing. We managed to solve the problem - it was bad motor controller.
  8. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Jan 2009
    Birmingham
    36 Post(s)
    A bad motor controller ? What is that
  9. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Oct 2016
    Poland
    Quote Originally Posted by arman123 View Post
    Sorry for my bad english - its engine ECU
  10. Re: Audi A4 1.9 TDI engine brb not starting no errors
    Jan 2009
    Birmingham
    36 Post(s)
    Did it have water ingress
  1. Audi Q7 VCDS errors
    By creatorul in forum VCDS - Help Requests
    Last Post: 22-01-2016, 10:11 PM
  2. Important 2006 Audi A4 B7 1.9TDI BRB Engine
    By bigpaul6 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-01-2016, 11:23 AM
  3. A4 1.9tdi 2007 BRB not starting after new camshaft fitted
    By beeswax in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2015, 12:27 AM
  4. Replies: 3
    Last Post: 21-12-2014, 10:36 AM
  5. Question Known faults of the 1.9 TDI engine with the BRB code and other questions...
    By Dejc in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-06-2012, 12:02 PM
