Re: Bluetooth Connection –
31-10-2016,04:44 AM
Originally Posted by
PCB
Hello again. Wow, you were busy! And thank you for looking into it for me.
I don't have vcds (yet) unfortunately so can't get the green menu. I've been into the red engineering menu and this screen appears...
I think 0040 is the lowest number I've seen on my mmi travels! Quite a way off from 9302.
Now, another thing, I read in one of these other threads that if you update firmware before fixing the bluetooth issue, it can ruin the MMI for good. Is this true?
As you said, all at my own risk so I'm still being a bit cautious.
Thanks... Paul.
You cant compare this 0040 with 9302 those are different things. Regarding bricking MU its always possible, this "no welcome screen" - i cant comment, but as stated, it was regarding bnav, no one on this thread is talking about sw update to BBT 0029 or higher. I had quick look into the update and looks to me that fix0020 and sw 0029 both have this fix marked under mu9302 with folder where is "41" inside...so estimated guess, this fix is already part of sw 0029-not a fact!
So its up to you how to proceed, install fix and after sw or any other order, or leave it as it is or dealer....even if you break the unit, after you can buy used bnav unit for 100-300 and enjoy nav also and if your present bt module will not work, just throw this away and enable bt which is inside of main unit. At least you get nav also and probably dealer will charge you same amount of money to fix your current situation!
BTW: i have seen new used audi owner, where bt module was disabled with optical loop(previous owner did not care about the bt fix) so who knows!
A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
