Thread: 2009 audi a6 fuse box location
Results 1 to 10 of 11
  1. 2009 audi a6 fuse box location
    Sep 2016
    Birmingham
    Hi guys just wanted to know apart from the fusebox at passenger side of dash and one on the right hand side of boot, are they anymore, I. E under the bonnet?
  2. Re: 2009 audi a6 fuse box location
    46 Post(s)
    Under the bonnet, one on the right hand side of the dash.
    What do you need to locate?
  3. Re: 2009 audi a6 fuse box location
    134 Post(s)
    2022 Post(s)
    There is one under the screen either side that doubles as a gold fish bowl....
  4. Re: 2009 audi a6 fuse box location
    Sep 2016
    Birmingham
    Thank you, fuse for cooling fan and inlet manifold flap
  5. Re: 2009 audi a6 fuse box location
    134 Post(s)
    2022 Post(s)
    Which engine code?
  6. Re: 2009 audi a6 fuse box location
    Sep 2016
    Birmingham
    Which engine code?
    Not sure of the engine code but it's a 59 reg 2.0d
  7. Re: 2009 audi a6 fuse box location
    134 Post(s)
    2022 Post(s)
    PD or CR?
  8. Re: 2009 audi a6 fuse box location
    Sep 2016
    Birmingham
    Quote Originally Posted by crasher View Post
    pd or cr?
    cr
  9. Re: 2009 audi a6 fuse box location
    134 Post(s)
    2022 Post(s)
    Probably a CAGB then. The fan fuse is number 42 in the left plenum chamber box, the one which fills with water, and is 40 amp for the standard duty single fan system. The manifold flap motor V157 is not fused.
  10. Re: 2009 audi a6 fuse box location
    Jun 2013
    Edinburgh
    Hi Crasher. Certainly not questioning your wisdom but my 2006 2.0 TDI (BRE) is showing fault P3102 - Motor for intake manifold flap (V157)- No signal. Everything I've read so far suggests the fuse may have blown though nobody states which one or where and I've spent a whole day looking for it. You're saying it's not actually fused at all, is that just for certain models? I opened the driver side plenum box and there is only one 40 amp fuse in there that looked ok. I'd like to get to the bottom of this as my EML is on and the limp mode light is flashing but like everything Audi, it seems impossible to get a definitive solution. Any suggestions?
  1. Fuse box location
    By bakili in forum Golf MK7 - 2013 - 2019
    Last Post: 31-03-2017, 11:09 PM
  2. Passat CC B6 Fuse Box Location and access
    By retro in forum Passat CC
    Last Post: 24-08-2013, 01:17 PM
  3. location of fuse box(s)??
    By dreddfan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-07-2012, 08:41 AM
  4. a4 tdi 1999 fuse box location?
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2008, 07:33 PM
  5. help, Location of internal fuse box
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:26 AM
