Thread: Volkswagen Golf 1.8T MK4 v68 positioning motor and v71 air flow flap
  1. Question Volkswagen Golf 1.8T MK4 v68 positioning motor and v71 air flow flap
    Mar 2014
    suffolk
    Hello,
    Recently scanned my Golf Mk4 on vcds and had the following codes come up.
    00528 Barometric Pressure sensor (F96) I assume this might be a map sensor but will ignore it for now
    00792 A/C Pressure switch (F129) Quoted £53.13 for genuine part
    01271 Positioning Motor (V68) Quoted £125.59 for genuine part
    01274 Air Flow Flap (v71) Quoted £125.59 for genuine part
    From my understanding the V71 is just for the re-circulation so not as important as the v68 motor flap.
    My Golf's heaters are terrible for both hot and cold air it seems stuck in the middle of both.
    What would a V68 flap be like to replace? and where behind the dash is it?
    Would a eBay replacement be a sensible option as its about £100 quid cheaper for what I assume is part number 1J2907511A but need to remove it first to confirm the part number.
    Any pictures of where this is would be greatly appreciated.
  2. Re: Volkswagen Golf 1.8T MK4 v68 positioning motor and v71 air flow flap
    131 Post(s)
    1973 Post(s)
    You have to remove the lower dash trim, glovebox and centre consul, it has to be set up using a diagnostic system in Basic Settings or the motor can be damaged. The V71 is evil to change, you have to jam your hand down the tiny gap between the intake and the A pillar, it rips your hands to shreds.
  3. Re: Volkswagen Golf 1.8T MK4 v68 positioning motor and v71 air flow flap
    Mar 2014
    suffolk
    I have vcds.
    Sounds like it is going to be a pain to change.
    I might see what it is like to remove before ordering a replacement then.
    Thanks for the reply.
  1. 01274 air flow flap positioning motor v71 faulty a3 8p
    By Kirk200 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-01-2016, 01:23 PM
  2. Air Flow Flap Positioning Motor (V71) - fault code 01274
    By VAGMAN2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2012, 07:26 PM
  3. 01274 - Air Flow Flap Positioning Motor (V71)
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2010, 02:14 PM
  4. V71 air flow flap motor faulty ?
    By lpg boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2008, 08:51 PM
  5. air flow positioning motor/climatronic problem
    By mslack in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2008, 08:13 PM
