Thread: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
  1. Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    Aug 2016
    Cambridge, UK
    Ive got a 1.9 TDI which i have had remapped, and also had a custom catback fitted to it, hitting around 140-150 BHP, now moving onto stage 3 with a new turbo, and going for a hybrid turbo. This will get me, with the right map around 180-200 Break, but do i need to up my injectors? or will, because it is hybrid, be fine?
  2. Re: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    131 Post(s)
    1974 Post(s)
    It will help to use the ASZ/ARL or 2 litre 8v injectors but the map will have to be dialled in to them. When you eventually blow it up, consider a 2L conversion, you can pull the lump out of a late Sharalraxy.
  3. Re: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    Aug 2016
    Cambridge, UK
    Elaborate on 2L conversion...?
  4. Re: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    131 Post(s)
    1974 Post(s)
    It makes a 1.9 into a 2L....... You take the engine out of a Sharan, Alhambra or Galaxy with a BVH or BRT engine and it comes with the high flow injectors, just add a decent hair dryer, remap to suit and break your gearbox.
  5. Re: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    Aug 2016
    Cambridge, UK
    And break my gearbox..?
  6. Re: Do i need to upgrade my injectors if i upgrade to a hybrid turbo? (1.9 TDI)
    131 Post(s)
    1974 Post(s)
    Well DMF first and when you make that stronger, then the box. Depends how you use it but if you build it, you SHOULD use it.
    0 2 0
  1. Advice on 1.9 tdi b6 turbo upgrade
    By jan.ursu in forum 1.9TDi - Engine
    Last Post: 09-10-2014, 12:44 PM
  2. Hybrid turbo upgrade info please.
    By deanosabby in forum 3.0TDi - Engine
    Last Post: 26-06-2014, 03:30 AM
  3. Question 150 tdi upgrade to hybrid stage 2 good or bad idea?
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 20-04-2010, 09:21 AM
  4. 2.5 tdi upgrade injectors
    By supermotodaz in forum The Commercial Range
    Last Post: 22-10-2007, 01:41 PM
