Thread: Noisy engine
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Question Noisy engine
    Sep 2007
    North Wales
    My 2008 B6 2.0TDi Sport Estate (BKP) has developed a tappety rattle on the top left hand side of the head. It hasn't lost any power neither has any lights appeared. I've had it scanned and there are no fault codes. Also when started from cold there is white smoke from the exhaust and the engine starts hunting, once it's warmed up it all settles down except the noise.
    Anybody got any ideas?? It runs too well for it to be a valve, I'm thinking maybe injector? But the lack of fault codes has thrown me.
    Thanks in advance.
    Steve
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  2. Re: Noisy engine
    1840 Post(s)
    That sound give the impression of an injector and that the noise is diesel knock rather than mechanical. The injectors used in that engine became notorious and were the subject of a recall, do you know if this was done?
  3. Re: Noisy engine
    Sep 2007
    North Wales
    Hi Crasher,
    Yes the injectors were replaced in 2011 as part of a recall. Spookily I made sure of that before I bought it 😡.
  4. Re: Noisy engine
    1840 Post(s)
    At five years old it is not inconceivable one is faulty, some deep analysis of the measuring blocks would be the first step.
  5. Re: Noisy engine
    Sep 2007
    North Wales
    Any idea which measuring block to look at?
  6. Re: Noisy engine
    1840 Post(s)
    13 and 18 off the top of my head but they are labelled in VCDS.
  7. Re: Noisy engine
    Sep 2007
    North Wales
    Hi again all,
    Firstly, thanks Crasher for you last reply.
    Story so far, I've had the injectors removed and tested, 3 came back as failed ������. I've now replaced all 4 at great expense. I have not seen the car since due to work commitments, however I am told it is still smoking and smelling of diesel when cold?? The garage said it is probably just excess diesel in the engine and DPF (which it hasn't got ��) and it would burn off. The oil and filter have been changed and I've been told to do it again after a 1000 miles. It also still sounds a bit tappety.
    Does this sound normal or is there likely going to be something else wrong??
    Any help greatly appreciated.
    Steve
    2.0 Passat TDi 130bhp Sport Estate (BKP) 2008
  8. Re: Noisy engine
    1840 Post(s)
    Where did the injectors come from? Did they fit new adjuster screws and ball studs then set the rocker arm stroke at maximum lift?
  9. Re: Noisy engine
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by Stevebt View Post
    Hi Crasher,
    Yes the injectors were replaced in 2011 as part of a recall. Spookily I made sure of that before I bought it .
    Maybe they weren't actually replaced. I imagine a part number check would confirm this.
    Ian
    A4 B6 Avant Nogaro Blue
  10. Re: Noisy engine
    Sep 2007
    North Wales
    Crasher, I'll have to ask the garage but I didn't see the screws on the bill. Is this part of the change procedure? Is it a key stage?
    Rowdy 999
    They were definitely replaced as my father still had the old ones when he picked the car up.
    Cheers for the replies both.
  1. Noisy Engine
    By Jumbo Golfer in forum Golf MK6 - 2009 - 2013
    Last Post: 09-04-2014, 12:09 PM
  2. noisy engine
    By zydrunas in forum VCDS - General Questions
    Last Post: 09-06-2013, 09:28 PM
  3. Noisy Engine
    By slowhand in forum Golf MK6 - 2009 - 2013
    Last Post: 13-10-2010, 07:59 PM
  4. Noisy engine!
    By nice1chris in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2008, 11:47 AM
  5. Noisy A4 2.0L Engine?
    By AudiSport in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2007, 08:41 PM
