Thread: Noisy engine
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. Re: Noisy engine
    #21
    Sep 2007
    North Wales
    It's a 3C I believe 2008 2.0 BKP engine.
  2. Re: Noisy engine
    #22
    1840 Post(s)
    So, you are sure the injectors have been changed during the recall and the fuel filter shows no sign of engine oil contamination?
  3. Re: Noisy engine
    #23
    Sep 2007
    North Wales
    1 injector was replaced by the previous owner and the the other 3 were done as part of the recall. I haven't looked at the filter but will do.
  4. Re: Noisy engine
    #24
    May 2012
    Everywhere
    308 Post(s)
    All this hassle and the engine and turbo are at risk from the 77mm .
    Time to get a parachute .
    1 1 0
  5. Re: Noisy engine
    #25
    Dec 2021
    România, Brașov
    Hi Steve! Sorry for reopening a 6 years old topic. I have the same symptoms with my BKP and for the last 3 years I have been struggling to find a solution to this problem. I've already replaced a set of injector units. Did you, by any chance, solved the problem?
    Thanks in advance!
    Andi
  6. Re: Noisy engine
    #26
    Sep 2007
    North Wales
    Quote Originally Posted by Andi Fox View Post
    Thanks in advance!
    Andi
    Hi Andi,
    No I’m afraid not. I part ex’d it in the end, I was honest about the fault it had. I needed a car for work so had to. I was going to try the pump next though if I’d of kept it.
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  7. Re: Noisy engine
    #27
    Dec 2021
    România, Brașov
    Thanks a lot for the feedback! Are you referring to the tandem pump (high pressure) or the fuel delivery module (low pressure)?
  8. Re: Noisy engine
    #28
    Sep 2007
    North Wales
    The tandem pump 👍.
  9. Re: Noisy engine
    #29
    Dec 2021
    România, Brașov
    Thanks again man! I'll give it a try cause it's driving me crazy. Have a nice evening!
  10. Re: Noisy engine
    #30
    Dec 2016
    lincoln
    24 Post(s)
    I had this exact fault on my B6 BMR. Turned out to be the Torsion Value that needs checking after a timing belt change just using VCDS. Out of 7 so called VW/AUDI specialists only 1 had ever heard of needing to do this (Worrying). So the 1 garage that knew about it who had actually found out through VW UK Technical sorted it out in under an hour. No more diesel smell or smoke out the back. Could not believe it was such a simple fix.
    Current Vehicles
    Passat B6 Estate 170PD (Bluefin Installed 200BHP) BMR Highline
    Aprilia RSV 1000 Factory
  1. Noisy Engine
    By Jumbo Golfer in forum Golf MK6 - 2009 - 2013
    Last Post: 09-04-2014, 12:09 PM
  2. noisy engine
    By zydrunas in forum VCDS - General Questions
    Last Post: 09-06-2013, 09:28 PM
  3. Noisy Engine
    By slowhand in forum Golf MK6 - 2009 - 2013
    Last Post: 13-10-2010, 07:59 PM
  4. Noisy engine!
    By nice1chris in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2008, 11:47 AM
  5. Noisy A4 2.0L Engine?
    By AudiSport in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2007, 08:41 PM
