Thread: OBDeleven first use - enabling rip CD's to MMI "Jukebo
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Quote Originally Posted by Nemo78 View Post
    How do I scan the car settings and have them sent to me by email before changing everything - can't work that out?
    I need to set up an email account for my android device but I think it might be under History. Will check tomorrow
    Former Q7 owner
  2. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    Ok also want to ask how do I enable the needle sweep? Module 17 is Dash board on OBD but in there I can't see anything re needle sweep?
    However a lot of the options that say 'No' I actually have?
    Module 17 corresponds to the number in the little green circle - as you say Dashboard.
    Following Andy's instructions:
    Coding:
    1. Module 17 (Instruments)
    2. Coding
    3. Long Coding - this is where you select 1 in top right
    4. Long Coding Helper - ignore
    5. Byte 1 (Second from left) - use green right arrow to move one step so Byte 01 is shown
    6. Tick/Select "Bit 0" - this will be the first row, select the check box and then apply the change and you're done
    7. Exit
    8. Do It - ignore
    To undo the change, do the same steps as above but uncheck Byte 01, Bit 0.
    Former Q7 owner
  3. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Jul 2010
    uk
    183 Post(s)
    Thanks srbsq7 - will try this tomorrow as chickened out and now indoors
  4. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Apr 2016
    Stansted
    169 Post(s)
    One thing that I thinks been mentioned before, to see needle sweep, you need to turn ignition on, wait for Audi logo / car to disappear and dials shown before starting engine.
    Former Q7 owner
  5. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Oct 2015
    Derby
    Haven't done it for a while but I think after performing a scan there's an envelope icon in upper right you click and enter your email address ( hopefully going to get time to do a few more changes tomorrow night so will confirm if nobody else has by then).
  6. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    Mar 2010
    37 Post(s)
    228 Post(s)
    please send me your scan's if you can via PM.. if you dont mind of course!
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  7. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    #17
    Apr 2016
    Stansted
    169 Post(s)
    Once you've made changes, if you go to Settings - Garage - Click on your Q7 - History - tap the mail icon at the top right.
    This will send all the changes you've made including before and after settings.
    Here's my settings - as you can see, the long coding change isn't easy to understand so my preference is to keep a manual log of what you've changed:
    5F Information Control Unit 1
    Date: 2016-09-14 12:24
    Mileage: 3132 km
    Adaptation: Copy multimedia data
    Optical drive:
    Old value: Off
    New value: On
    Date: 2016-09-14 12:23
    Mileage: 3132 km
    Long coding:
    Old value: 013706010000000013111102000A00332F001BE7017001009E
    New value: 013706010000000013111102000A00332F001BE701700100BE
    Former Q7 owner
  8. OBDeleven first use - enabling rip CD's to MMI "Jukebo
    #18
    Jul 2010
    uk
    183 Post(s)
    Andy and srbsq7 thanks for the step by step guide above!! Finally got the needle sweep activated and lap timer - however for some reason that isn't showing in HUD only in VC
  9. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    #19
    Apr 2016
    Stansted
    169 Post(s)
    Glad it's helpful. With the lap timer, did you start it running and then drive off? From memory it doesn't show on the HUD until you move
    Former Q7 owner
  10. Re: OBDeleven first use - enabling rip CD's to MMI "Jukebo
    #20
    Jul 2010
    uk
    183 Post(s)
    Quote Originally Posted by srbsq7 View Post
    Spot on...I was looking at it whilst standing still but later when driving it came on to HUD.
  1. OBDeleven news
    By wolek76 in forum Q7 - 4M Forum - 2016 -
    Last Post: 21-07-2016, 04:47 PM
  2. MMI+ Nav Google Earth error: "Not Enough Data in Memory"
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2014, 08:28 PM
  3. Enabling the 'Touring Mode' to appear in MMI
    By rovervampire in forum VCDS - General Questions
    Last Post: 11-05-2013, 01:39 PM
  4. Audi A6 Avant 2006 MMI "Telephone Not Installed" issue
    By moet546 in forum VCDS - Help Requests
    Last Post: 04-03-2012, 12:20 PM
  5. Question Audi A6 Avant 2006 MMI "Telephone Not Installed" issue
    By moet546 in forum In Car Entertainment
    Last Post: 24-02-2012, 11:44 AM
