Thread: Peeling buttons
Results 1 to 10 of 11
  1. Peeling buttons
    Aug 2016
    Stoke
    7 Post(s)
    I can tell this topic has been covered a thousand times, but many are out of date and have dead links now.
    How do people overcome the peeling button issue, without spending 100's on replacement units? Currently, my ESP switch has a big peel, the OFF switch on the climate is very bad, the window switches are bad. Pretty much the whole lot is bad
    I've seen a lot of fake aftermarket switches for cheap that I can order, I'm wondering if they've used a cheap plastic without the rubber, it might actually be more long-lasting than these awful rubbery switches.
    Thoughts?
  2. Re: Peeling buttons
    Nov 2008
    Leeming
    Audi A4 8E B6 Getränkehalter / ESP Restaurations Set
    I have just replaced my aircon, RNS-D and open roof buttons
    Not cheap but cheaper than new units
  3. Re: Peeling buttons
    Aug 2016
    Stoke
    7 Post(s)
    Funnily enough, the only two that aren't suffering from peeling are the cup holder and tray. That said I'll have a look if they do the other ones. I've noticed these guys are knocking out something very similar:
    Audi A4 B6 8E CLIMATE HEATER CONTROL peeling worn buttons button knob repair | eBay
    But I just wasn't all that convinced by the quality.
    Certainly these:
    Audi A4 8E B6 B7 Air conditioning Control unit/Climate Buttons Restaurations Set | eBay
    From the same guys you linked, seem a lot better quality (just visually at least), so I might plump a twenty and go for that. Were you required to acetone the rest of the rubber off with yours, because apparently the ones I linked above expect you too, which I always think is a bit of a risk in itself?
  4. Re: Peeling buttons
    Nov 2008
    Leeming
  5. Re: Peeling buttons
    Aug 2016
    Stoke
    7 Post(s)
    How do yours look? Have you got any photos?
  6. Re: Peeling buttons
    Nov 2008
    Leeming
    Only had my car a month, unfortunately I have a list as long as my arm of things to do I haven't actually got round to installing them yet.
  7. Re: Peeling buttons
    Aug 2016
    Stoke
    7 Post(s)
    Now onto this.... Along with a load more jobs
  8. Re: Peeling buttons
    Jan 2016
    Norway
    i did this with my CD player and some other buttons. Didn't look quite as good as original, but pretty good. Bought vinyl stickers from some guy from Portugal on eBay. I acetoned it with cotton swabs and removed any flakes, but didn't remove all of the original cover. Good luck!
  9. Re: Peeling buttons
    Aug 2016
    Stoke
    7 Post(s)
    Any photos?
  10. Re: Peeling buttons
    Mar 2006
    county durham (north east uk)
    Someone had done my heater panel & cd player with button stickers before i bought it, looked ok until the hotter weather, they then started to bubble & looked terrible,
    I ended up taking the heater panel to bits & swapping some good second hand buttons from a couple of units from the breakers yards & the cd player i bought a good one from e bay cheap with no code & just swapped the front of it over with mine,
    Was quite an easy job
  1. Peeling coating on electric window buttons
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2014, 09:59 AM
  2. Wheels Peeling
    By SattyA4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-02-2014, 04:11 PM
  3. Peeling wheel lacquer
    By mkc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-07-2009, 08:38 PM
  4. Peeling Trim Rings (?)
    By brettvds in forum Wheels and Tyres
    Last Post: 10-01-2009, 07:32 PM
  5. Trim peeling off
    By Photobloke in forum Bora - 1998 - 2005
    Last Post: 25-08-2008, 12:11 PM
