Thread: LT35 Coolant sensor
  1. Question LT35 Coolant sensor
    Hi I have just bought a 1986 LT35 2.4Tdi campervan and have noticed that sometimes the coolant sensor light will come on, but if I switch off and start up again the coolant indicator does not flash. Whilst all this is happenig the temperatur needle appears to rise gradully in the normal way. I have been told by the previous owner that it is a faulty sensor. IS THIS CORRECT and how/where would I get one. I beleive that it just goes into the coolant reservoir and is coonected via " wires??????. Any assistance would be useful.
    I am a complete novice so please be gentle Yours in Hope Bugzee
  2. Re: LT35 Coolant sensor
    Hi We bought an LT3.5 N reg camper from a dealer n Derby and it had a similar problem. The waring LED would flash, when you pulled over stopped the engine, re started it would flash for the check period and then go out. I think the senor it is wired to is the level sensor which is in the water filler cap. I suspected that an air lock gets into the system and the bubble trips te sensor, causing the light to flash.
  3. Re: LT35 Coolant sensor
    Aug 2008
    I have a 1990 lt 35, I have traces of oil in the coolant and it covers the water sensor and causes the warning light to flash, once the sensor is cleaned and refitted light goes out. Dont know where the oil is coming from, no overheating, loss of power or water in the engine oil. What to do?
  1. VW MK4 GTi Coolant sensor
    By gonie in forum Chat - Anything with wheels
    Last Post: 16-10-2007, 08:26 PM
  2. coolant temp sensor in APT 1.8 20v
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2007, 02:23 PM
  3. mk3 coolant temp sensor
    By pazur in forum Vento - 1994 - 1998
    Last Post: 05-08-2007, 05:53 PM
  4. Coolant sensor info pls !
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 21-07-2007, 11:47 AM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
