Thread: Multiple diag codes - what do I fix first - Help!
  1. Question Multiple diag codes - what do I fix first - Help!
    Sep 2016
    Cambridge
    My 17 year old son's car 2004 Polo twist has recently had a engine light come on, diag reports CAT problem P0420.
    Did an emissions test and all seemed fine so cleared code.
    While ignoring it for last couple of weeks engine light came on again, tried to clear it by disconnecting battery (did not work).
    Next day, car started rev hunting, and going around corners could stall etc. EPM light comes on sometimes. Other times car starts fine and drives fine.
    Today, did diag and new set of codes though now being reported:
    P1565 - Throttle actuator
    P1579 - Throttle body related
    P0106 - Manifold pressure sensor related
    P0172 - Fuel too rich?
    Garage are asking me what I would like to do!?
    Suddenly in to scary territory with cost, but could one of these problems be triggering the others?
    Please help!
  2. Re: Multiple diag codes - what do I fix first - Help!
    Jul 2007
    glasgow
    35 Post(s)
    VAG Error Code: 16804
    EOBD II Error Code: P0420
    Fault Location:
    Catalytic Converter System, Bank 1 - Efficiency Below Threshold
    Possible Cause:
    Leakage in Intake and/or Exhaust System.
    Catalyst faulty.
    Oxygen Sensor(s) faulty.
    Oxygen Sensor(s) Control faulty.
    Possible Solutions:
    Check Intake and Exhaust System for Leaks.
    Check Catalyst.
    Check Oxygen Sensor(s).
    Check Oxygen Sensor(s) Control.
    Perform Oxygen Sensor(s) Aging Check.
    Is the pipes leading to air filter on ?
    the oxygen sensor may be faulty if the fuel mix is too strong ?
    is the air filter clean ??? I would replace the air filter for a new one for a start
  3. Re: Multiple diag codes - what do I fix first - Help!
    134 Post(s)
    2002 Post(s)
    Remove and thoroughly (but gently) clean the throttle body, it will be solid with EGR deposits on the back, use an aerosol carb/injection cleaner and stiff nylon bush, you must not scratch the bore or butterfly edges. Then the TB will need re-matching to the ECU which is done in Basic Settings 060 with a diagnostic system such as VCDS.
  4. Re: Multiple diag codes - what do I fix first - Help!
    Sep 2016
    Cambridge
    Thanks for your help.
    Had the throttle body cleaned and the ECU recalibrated, for now this seems to have done the trick.
    While doing this the garage found a split in a pipe, although it is not clear which pipe or what it was doing and if this is related. Anyway, this has been replaced.
    We changed the air filter not long ago so this should be fine.
    I have a feeling the engine light will come on again soon, let's see what the code will be!
  5. Re: Multiple diag codes - what do I fix first - Help!
    134 Post(s)
    2002 Post(s)
    Probably poor catalyst efficiency caused by over fuelling due to the air leak that has now been fixed.
  6. Re: Multiple diag codes - what do I fix first - Help!
    Sep 2016
    Cambridge
    Confirmed it was an air pipe that had a split. Still no light. Keeping fingers crossed.
    Thanks for help.
  1. Multiple thrown codes
    By Dylan07 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-10-2015, 02:28 AM
  2. Please Help Multiple fault codes after car gradually loses power and drive
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2015, 07:47 PM
  3. Question Q7 VCDS Diag Codes - Emmision Control System error on DASH
    By Spud312r in forum VCDS - Help Requests
    Last Post: 16-12-2014, 03:51 PM
  4. Question 2007 A4 2.0 TFSI with multiple fault codes
    By lasosage in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-09-2014, 02:13 PM
  5. Please Help TDI loss of power multiple Vag-Com codes
    By norfolkboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2010, 11:03 PM
