Thread: Noise... what is it?
  1. Noise... what is it?
    London,UK
    i just picked up a 2003 1.8 audi T Sports cabriolet... its all good expect there is a knocking/rattle noise coming from the part where the roof meets the windscreen.. its more to the passengers side & happens when driving in London going over uneven road surface or a drain plate/small pot hole or even a road hump..what could it be? what can i do?
    info really appreciated as worrying me...
    thanks
  2. Re: Noise... what is it?
    Sep 2007
    hi if you open the roof half way you will see an allan bolt on the roof fame . try tighting it on both the drivers side and passengers. Then spray all the hinged pars with a silicon spray (cockpit trim shine) this should cure it . it did to mine .
    PAPALION
  3. Re: Noise... what is it?
    London,UK
    Many thanks for the info.. it worked.. the noise is now gone.. much appreciation for the info... just need to have a good roof cleaner now... can see some marks coming... all the best.
  4. Re: Noise... what is it?
    Sep 2007
    hi i use a cleaner i got from a classiic restorer a firm called WOLLIES good stuff . also auto glim do a good water repelant . papalion
  1. What's the noise?
    By Benners in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2007, 10:24 PM
  2. Worrying Noise
    By GSD in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2007, 08:04 AM
  3. got a noise
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 05:02 PM
  4. Noise!!
    By Dips in forum Audi A3 - Archive Topics
    Last Post: 29-04-2007, 02:34 PM
  5. S3 turbo noise
    By markclemo in forum Audi A3 - Archive Topics
    Last Post: 12-02-2007, 01:44 AM
