Thread: Touran clutch master cyclinder
  1. Touran clutch master cyclinder
    Jan 2015
    wrexham
    Evening all, I have an issue with my 53 plate touran 1.9tdi. The first half of the clutch pedal press does nothing and only engages at the bottom half, I have no clutch slip but the bite is right at the bottom, sometimes the pedal does stick at the halfway point and looking down at the master cyclinder on the pedal it looks like (hoping) this is to blame. Am I barking up the wrong tree and really it is the clutch gone? If it is the master cyclinder how are they changed?
  2. Re: Touran clutch master cyclinder
    Jun 2010
    London
    try bleeding it first. you've got master cylinder and slave cylinder. im not sure how to test them, i believe when they fail, it starts leaking.
  3. Re: Touran clutch master cyclinder
    Jan 2015
    wrexham
    So, I've changed the master cyclinder for a new one. Bled it, and bled it again but still there's no pressure there till the pedal is half way down, this is what is stopping the pedal from coming back up. I'm assuming it probably the release bearing worn and has play in it? I can hear a slight change in noise when I press the clutch too
  4. Re: Touran clutch master cyclinder
    Jan 2015
    wrexham
    So just to update this for anyone searching, the fault was actually the slave cylinder. Didn't even think about that until I'd purchased a flywheel and clutch and was mid way through stripping. The boot of the slave had perished completely thus allowing dust on the shaft and stopping the slave cylinder moving freely!
  1. Clutch master cylinder
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-09-2012, 10:17 PM
  2. Please Help Touran Clutch Master Cylinder
    By sicknote in forum Touran - Sharan - Caravelle
    Last Post: 09-12-2010, 05:18 PM
  3. Brake master cyclinder help
    By mattk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2010, 08:50 PM
  4. clutch master cylinder
    By and32 in forum Audi A3 - Archive Topics
    Last Post: 08-03-2009, 05:21 PM
  5. Clutch Master Cylinder Keeps Going?
    By NOGGA in forum Bora - 1998 - 2005
    Last Post: 22-09-2007, 09:02 PM
