Thread: Rough running
Results 1 to 9 of 9
  1. Rough running
    Please help! I have a golf gti 8V with an AGG Engine which runs rough when hot. The problem is for some reason the CO Emission content goes excessivley rich and logs a fault in the ECU with oxygen sensor upper limit reached. Can anyone help?
  2. Re: Rough running
    Sep 2007
    had the same prob in my mk3 gti same engine.. and same fault shown on the computer.. i bought a second hand sensor from the scrappie.cost 20 pounds..( 103 pound from main dealer) replaced the sensor and now every thing is fine. realy easy t0 replace as the lambda sits just in front of the catalyst..on the pipe. cant miss this as is the only thing screwed in looks a bit like a chunky spark plug. follow the wire to connector towards the engine unplug this unsrew the sensor..and replace.. u may need a pair of pliers to cut the tie holding the wire.. and another tie to replace this.... make sure that the sensor and exhaust sytem is cool before you attempt this save u making the same mistake i did.
  3. Re: Rough running
    thanks for the reply, but i have already tried the lambda probe route and it hasn't worked! oh well!!!! thinking it could be ecu
  4. Re: Rough running
    Quote Originally Posted by andrew.butler57 View Post
    My car jerk when it warms up. I thought it had something to do with tension leads, I replaced them. Is it probably the coil? The idling is terrible!
  5. Re: Rough running
    My Golf jerks up when it hots up. I have replaced the tension leads but all in vain. Could it be the coil?
  6. Re: Rough running
    Someone help me with my jerking car.
  7. Re: Rough running
    Quote Originally Posted by ntatedeuce View Post
    you need to give more information about your car, model/year/engine code and have you tried reading the diognostics (error) codes from your car yet?
  8. Re: Rough running
    I have a VW Golf III 1994. The idling is poor. When the car hots up, it jerks. Could it be a coil.....
  9. Re: Rough running
    Could be lots of things, my '95 1.8i ADZ had poor Idle and drops in power whilst driving once it heated up and it was the TPS that had gone (£80 new from GSF and 5 mins to fit).
    You really need to do a fault reading and check your air/fuel system (check filter and check pipes for splits).. Check your plugs.. I could go on, but i won't...
    You need to give more information like what engine your car has..
    Get yourself a VAG-COM lead of eBay (Around £15, check 1st what type of connection you have) and get the VAG-COM software (free)
    Then report back here, or you could get random people telling you what fixed their similar problem and in the end you might get lucky or you could spend £100's on replacing parts that didn't need replacing and still have the problem, but the more information you can give here the more people will be able to help you
  1. MKIII Golf GTi rough running
    By ESibley in forum Golf MK3 - 1993 - 1999
    Last Post: 18-10-2007, 09:24 PM
  2. Touran Running Rough
    By Cranley Bob in forum Touran - Sharan - Caravelle
    Last Post: 19-07-2007, 07:45 AM
  3. audi a3 running rough once warm
    By bobby8595 in forum Archive posts
    Last Post: 20-04-2007, 06:14 PM
  4. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  5. Rough running after service 1.9tdi - ECU ??
    By nicknicknick in forum Passat - Archive Topics
    Last Post: 29-12-2006, 08:01 PM
