Thread: EGR valve insufficient flow
Results 1 to 10 of 13
  1. Question EGR valve insufficient flow
    Nov 2015
    Inverness
    Hi all
    I took my car to audi to get a diagnostic check done came back as egr valve insufficient flow.
    Bought a new siemens EGR valve and I am Still getting the same fault code
    The pipe feeding the egr valve has slight oily/sooty coating on the inside which can be wiped off with your finger. No blockages in the pipe.
    What else could cause this fault?
    2005 Audi A4 2.0Tdi
  2. Re: EGR valve insufficient flow
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Whats the history behind taking I to main dealers for a code read?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: EGR valve insufficient flow
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    if it's the siemens electric valve rather than the vacuum operated i think you need to use 'adaptations' in VCDS to set it up. I could be wrong though.
  4. Re: EGR valve insufficient flow
    Nov 2015
    Inverness
    Thanks for the replies
    I replaced electric valve with electric valve.
  5. Re: EGR valve insufficient flow
    Nov 2010
    104 Post(s)
  6. Re: EGR valve insufficient flow
    Nov 2015
    Inverness
    Thanks for the reply
    How do you test the egr cooler is working as there is a actuator mounted on the end of it?
  7. Re: EGR valve insufficient flow
    Nov 2010
    104 Post(s)
    Presume you mean the EGR valve having an actuator on the end of it? - you need VCDS and use 'measuring blocks' to check it's functioning. Maybe you need to take it to a garage to get it checked / set up.
  8. Re: EGR valve insufficient flow
    Nov 2015
    Inverness
    On the end of the egr cooler there is a actuator to direct the exhaust gasses through the cooler when required.
    How do you test if it's working
  9. Re: EGR valve insufficient flow
    chester
    17 Post(s)
    A vac pump,see if it holds closed and follow the hose back check for splits.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  10. Re: EGR valve insufficient flow
    Nov 2015
    Inverness
    Thanks for the reply.
    I'll check it and report back.
  1. P401 egr insufficient flow
    By Nasif Khan in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-02-2020, 12:01 AM
  2. Question P0401 EGR insufficient flow
    By passatwoes in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2016, 05:30 AM
  3. Audi A6 2.7TDI w. fault code: EGR System - Insufficient Flow - Intermittent
    By MartinCB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-04-2016, 01:26 PM
  4. 16785 - EGR System: Insufficient Flow
    By chrisgeary in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-11-2011, 10:24 PM
  5. EGR insufficient flow on Golf GT TDI mark v
    By aggie in forum Golf MK5 - 2004 - 2009
    Last Post: 06-07-2010, 01:21 PM
