Thread: Specialist spannerman req'd
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Specialist spannerman req'd
    #21
    2007 Post(s)
    You do realise that it is possibly this that is causing the problem don't you? It always pays to check the basics. The rotor arm will need to be broken off, I remove the dizzy (sometimes a nightmare in itself as it gets corroded in) and crush the rotor in a vice. If you remove the dizzy, it will need to be set up again in measuring blocks 08 so you will need VAG-COM or something like it.
  2. Re: Specialist spannerman req'd
    #22
    Oct 2007
    Romford, Essex
    Yes I do realise that, I'm hoping that this is the prob. I stand a chance of fixing it then?
    Crushing ing it in a vice sounds like a safe way to remove it! Vagcom sounds a bit more tricky....
    ThankQ!
  3. Re: Specialist spannerman req'd
    #23
    2007 Post(s)
    Taking the dizzy out could give you problems so crush the rotor in position using some mole grips. Cover the internals of the dizzy with a cloth to stop bits dropping inside.
  4. Re: Specialist spannerman req'd
    #24
    Oct 2007
    Romford, Essex
    I'll pop up the ******** int'mornin for a new dizzy-n-rotor arm.
    I'll et you know how I get on.
    again!
  5. Re: Specialist spannerman req'd
    #25
    2007 Post(s)
    There are two types of dizzy used, Bosch or Sagem. The part numbers for Bosch are (cap) 051 905 207 £12.04 and (rotor) 052 905 225 C £9.40 and for Sagem (cap) 026 905 207 A £10.58 and (rotor) 026 905 225K £11.16.
  6. Re: Specialist spannerman req'd
    #26
    Oct 2007
    Romford, Essex
    You really are the most fella(?), top posting!
    I used a pipe wrench to nibble off the ends of the rotor arm. Then used a nut splitter that I bought about 300yrs ago and dont think I have ever used until now! That'll be the easiest job that'll have to do!
  1. VW Specialist in Manchester
    By shahid1973 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 18-01-2011, 08:46 PM
  2. Going to a volkswagen specialist?
    By Oddball in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-08-2007, 06:44 PM
  3. VW Specialist in NW London
    By keano16 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 06-06-2007, 10:28 AM
  4. Does anyone know of a VW specialist in Glasgow
    By PAUL_MCMINN in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-05-2007, 03:55 AM
