Thread: help please Polo 1.4 tdi 9N3 error relay J17
  1. help please Polo 1.4 tdi 9N3 error relay J17
    Mar 2009
    Chester, Cheshire
    Polo 1.4 Tdi, 2005/6, face lift model
    I would be grateful if anyone could share any experience that have had with this or a similar problem.
    Car runs fine, engine light comes on after a few miles, seems to run fine.
    The error codes reported are:
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-10 - - Intermittent
    19461 - Relay for High-Output Preheating of Coolant (J360)
    P3005 - 35-10 - Short to Plus - Intermittent
    18027 - Glow Plug Relay (J52)
    P1619 - 35-10 - Open or Short to Ground - Intermittent
    17910 - Fuel Pump Relay (J17)
    P1502 - 35-10 - Short to Plus - Intermittent
    If I clear them, the one that keeps coming back is:
    I am having trouble finding this relay, the suggestion is that it is under the steering wheel, and there are a few there but I do not believe it is the fuel pump relay
    Any help or guidance appreciated
    Audi A4 Avant, B8, 3.0 tdi, Quattro. 18" 5 spoke wheels, Black leather, Sat Nav, MMI, Sports Seats, Heated seats, Electric Seats, Electric tailgate, B&O Sound system, Lighting pack, Dynamic Steering, Panoramic Sunroof,
  2. Re: help please Polo 1.4 tdi 9N3 error relay J17
    Apr 2016
    Ashburton
    you want to replace the Relay 409 which is located on the relay plate rail located behind the fuse box which is on the side of the dash when you open the drivers door. To gain access you need to remove the whole section.
    The picture below is from a left hand drive vw relay plate is behind the removable grey panel below the light switch. If you remove the panel above the foot pedals you should see the relays.
  3. Re: help please Polo 1.4 tdi 9N3 error relay J17
    Mar 2009
    Chester, Cheshire
    Quote Originally Posted by turboextreme View Post
    Thanks, Turboextreme.
    I have had a very good look around there, have found a number of small relays, but not one marked 409
    I will have a much better look again
    Thanks.
  1. Heated leathers in 9n/9n3 Polo
    By anoop.9n3 in forum Chat - Anything with wheels
    Last Post: 26-11-2012, 01:18 AM
  2. polo 1.2 2006 (9n3)
    By warptechno in forum Polo - Derby - Lupo - Fox
    Last Post: 10-05-2011, 01:27 PM
  3. polo 2006 1.2L (9n3)
    By warptechno in forum VCDS - Help Requests
    Last Post: 10-05-2011, 10:42 AM
  4. Important Can we install polo 9n3's steering wheel to my 2004 model Polo 9N?
    By polo38 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2010, 09:32 PM
  5. New Polo 9n3 Owner :)
    By josh in forum Polo - Derby - Lupo - Fox
    Last Post: 26-07-2010, 08:12 PM
