Thread: Clicking noise when pulling out at junctions
Results 1 to 9 of 9
  1. Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    Hi all,
    I have an 2015 A6 Sline BE. I noticed from very early on in ownership that there is a clicking noise coming from the front of the car when pulling out at t junctions. Sounds like the drive shaft as it is more noticeable if I need to accelerate quickly from a standstill when the steering wheel is partially turned in either direction. I have never heard it when accelerating in a straight line.
    I asked Audi dealer to check it when it was in for service but they trotted out the line "we could not replicate the sound/issue"
    Anyone else had this issue.
    Cheers,
    Kevin.
    Kevin
  2. Re: Clicking noise when pulling out at junctions
    Jan 2010
    southport
    I would go back to Audi and ask to speak to the service manager. Tell him that you want to take him out in the car. That way he will hear the sound in the conditions that makes it happen. They should then be able to fix it and test drive the car to make sure it's safe and fixed. When a cv joint is on its way out it will click under load on an angle. I would want to have it fixed pretty quick tho.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  3. Re: Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    Strange that the clicking has been happening from new though?
    Kevin
  4. Re: Clicking noise when pulling out at junctions
    Jan 2010
    southport
    All the more reason to get it into Audi ASAP.
    0 2 0
  5. Re: Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    Hoping to get to dealer tomorrow to have the noise checked again. Has any one else had a similar issue, happens in both directions?
    Kevin
  6. Re: Clicking noise when pulling out at junctions
    Jun 2015
    Europe
    Will likely be drive shaft/Cv joint i had similar but that was after a kerb bash and was not a factory failure. Same experience pulling out from junctions with wheel on lock click click click got progressively worse. New drive shaft / Cv joint fixed the issue.
    It'll be covered under warranty in your case.
  7. Re: Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    Diagnosed as left cv joint as expected. Strange for a failure so quick. Only 35,000 km on the clock and have been hearing the symptoms from new pretty much.
    Kevin
    1 1 0
  8. Re: Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    Update: car went in Tuesday to have the left cv replaced even though I had told them that the noise seemed like it was coming from the right. Anyway what would I know as they had already had the car in for diagnosis a couple of weeks before.
    Called to pick it up and had a chat with the SA and he said all was fine cv replaced and test driven by 2 people. All good I thought.
    Hoped into car and as I pulled out of the dealerships Click, Click , click!!!
    Went straight back in and told the SA that the car had not been repaired. I think he thought I was joking at first! He arranged for service manager to go for test drive with me again and in the end he has agreed that they repaired the wrong side and that they should have repairs the right side as I had said. Booked in for right side repair tomorrow morning so fingers crossed that it'll be sorted.
    On another note was chatting to a friend who had another 2015 Sline a6 and he had his in 2 weeks previously for the same cv repair. There must be a common fault there somewhere...
    Kevin
  9. Re: Clicking noise when pulling out at junctions
    Feb 2015
    Sligo, Ireland
    All sorted after yesterday's visit to garage. Both sides now replaced so hopefully that's an end to the clicking
    Kevin
  1. Question Noise when pulling away
    By appoman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-11-2018, 04:25 PM
  2. Please Help Strange noise when pulling off with some steering lock!
    By Steven L in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2014, 05:08 PM
  3. Noise pulling away
    By hutchi102 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-05-2011, 08:16 PM
  4. Noise when pulling away
    By slimgeo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-03-2010, 05:36 PM
  5. Clutch noise when pulling away
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-07-2009, 02:20 PM
