Thread: Electrical issue. Weirdness. Brake warning.
Results 11 to 20 of 28
  1. Re: Electrical issue. Weirdness. Brake warning.
    Apr 2016
    Manchester
    Quote Originally Posted by SammoVWT View Post
    From my experience an old worn out and partially damaged regulator will do this under load - stuttering etc, but at idle may be able to keep things ticking over.
    Check the battery voltage with the car off, at idle, and alternator output across the battery at 2000 RPM. I would like to think your car is young enough to not have any wiring issues, but give the harnesses a look over to make sure there are no shorts to eachother or ground. Check battery terminals etc.
    Not had any wet footwells or anything recently?
    Funnily enough, passenger foot well was wet a week or two ago.
    I poked my fingers in the drains under the battery and a ton of water came out.
    2006 Audi A4 B7 Avant 2.0 TFSI S Line Quattro tiptronic in Phantom Black.
  2. Re: Electrical issue. Weirdness. Brake warning.
    Apr 2016
    Manchester
    Just did a forum search and came up with this relating to the fault codes...
    18693/P2261/008801 - Ross-Tech Wiki
    /P2261/008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    Possible Causes
    Boost Pressure Control Valve (N249) faulty
    Wiring/Connectors from/to Boost Pressure Control Valve (N249) faulty
    Possible Solutions
    Check Boost Pressure Control Valve (N249)
    Check Wiring/Connectors from/to Boost Pressure Control Valve (N249)
    Special Notes
    Visually check the N249 valve for a split diaphragm and replace the faulty component with the latest revision as per the parts management system and various TSB/TPIs which include but are not limited to:
    VW TPIs 2023024 and 2016986
  3. Re: Electrical issue. Weirdness. Brake warning.
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I wouldnt worry about that code.Now, your plenum chamber full of water is another issue! It could very well be related.
    Alan.
    VW T6 150 DSG Camper £££
  4. Electrical issue. Weirdness. Brake warning.
    Apr 2016
    Manchester
    Plenum chamber? Is that the battery tray area?
    It's dry as a bone, as is the passenger footwell too.
  5. Re: Electrical issue. Weirdness. Brake warning.
    Sep 2009
    London/Bucks England
    Are the drain channels blocked? The footwell gets flooded when the drain channels aren't clear and water fills up and seeps in via seals or usually via the cabin filter etc. Water drips in, finds its way to all the lowest connector sockets and causes lots of shorts etc. Can leave corrosion behind and sometimes kill off electronic modules. You might have gotten off lucky, I've only had my footwell a little wet once, because I missed my annual leaf clearing schedule one year..
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  6. Re: Electrical issue. Weirdness. Brake warning.
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Quite often when you get the big brake warning symbol, and all your brake components (lines,fluid,discs,pads,sensors etc) are all good, the issue is that your battery is about to die.
    The idea is that a braking fault warning will force you to park up and inspect the car, as you are, and seek advice,as you are, this is because many parts of the car rely on a perfect supply of electricity, lights, abs etc, this is why I would suggest a battery and charging health check might be prudent and potentially a cheapish solution
    Stuart
  7. Re: Electrical issue. Weirdness. Brake warning.
    #17
    Apr 2016
    Manchester
    Battery is brand new.
    Alternator is charging as it should. Checked it with a meter to make sure it wasn't drawing power.
    Out of curiosity where's the n249 boost pressure control valve??
  8. Re: Electrical issue. Weirdness. Brake warning.
    #18
    Sep 2009
    What voltages are you getting on the system? Are the battery connections on properly? I would expect that valve to be somewhere near the turbo. I've had a whole bunch of electrical faults lately, mostly due to old/frayed wiring and cracked insulation, its not fun work diagnosing these issues - has the valve code come back?
    I'm not sure what module you have under the footwell, just hoping you dont have any residual water behind there. I would be tempted to run the AC on cold just to dehumidify it a bit - I dont have that luxury!
    P1602 power supply undervoltage - This one is what concerns me most
  9. Re: Electrical issue. Weirdness. Brake warning.
    #19
    Apr 2016
    Manchester
    Battery connections are fine. Alternator is running 13.8 volts.
    May be my imagination but the car seems to be running smoother having had the error codes erased.
    None have popped up again since.
  10. Re: Electrical issue. Weirdness. Brake warning.
    #20
    Sep 2009
    Voltage seems good, assuming that's at idle?
    You might be lucky since it's all dried out now - just make sure your drains are clear so when we get another downpour it doesnt flood again. Its always one of those things you wish you had done in hindsight - keep an eye on it though, you will know where to start looking if you get issues again
    The joy of intermittent faults!
  1. A6 Avant 2.0 Tdi brake pad warning light issue
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2015, 01:45 PM
  2. Funny Electrical Issue
    By h20ruf in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 16-08-2014, 10:33 AM
  3. Electrical gremlins cause phantom brake warning, help please !
    By jzbdski in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-01-2013, 01:41 AM
  4. Please Help Electrical Issue, I think?
    By Mxyeow in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2010, 04:41 PM
  5. Please Help Brake pedal weirdness - Unwelcome ABS?
    By constablechris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2009, 11:21 PM
