Thread: About to cry! 1.9 tdi flooding with diesel
Results 1 to 10 of 10
  1. About to cry! 1.9 tdi flooding with diesel
    Aug 2016
    N.wales
    First of all hi new member and first post
    I have done a search but now nothing matches
    i have a 51 plate a4 estate 1.9 tdi 200k miles (pulled a lot better than my 59 avant did) it had a remap when I bought it few months ago.
    a week ago noticed it started to smoke which only got worse so I left it at the garage who couldn't diagnose as its been remapped?
    so I picked it up and the turbo blew on the way home replaced it yesterday with a brand new one ran fine for 30 mins and now the engine just locks with diesel I remove the glow plugs starts again for 30 seconds and does the same
    the temp gauge is stuck at 70 even with the key out and I've put a new temp sensor in?
    i know the cars not worth it but we're having a baby in a few weeks and can't afford a new car
    any help is appriciated
    thanks
  2. Re: About to cry! 1.9 tdi flooding with diesel
    Pembrokeshire
    22 Post(s)
    so one of your injectors is stuck open. remove the glow plugs, crank it over and see which one squirts out copious amounts of diesel, and replace that injector. it will then be fine as long as no other injectors are broke and you havn't bent a rod when it hydrauliced itself.
    0 2 0
  3. Re: About to cry! 1.9 tdi flooding with diesel
    Aug 2016
    N.wales
    I have done and 1 3 4 chuck it out but would 3 all go at once ?
  4. Re: About to cry! 1.9 tdi flooding with diesel
    Pembrokeshire
    22 Post(s)
    try unplugging the injector harness , the big round plug at the back of the head and trying again.
  5. Re: About to cry! 1.9 tdi flooding with diesel
    Aug 2016
    N.wales
    Ahh I no the one I unplugged that to purge the turbo. I was wondering if I could put it in the wrong way or something .
    sorry about this I'm more of a carb type fella but what am I hoping for with it disconected
  6. Re: About to cry! 1.9 tdi flooding with diesel
    Pembrokeshire
    22 Post(s)
    well that powers the injectors to allow them to fire. if diesel still squirts out with that plug undone then it must be an injector fault. however, if no diesel squirts out then the blame must lie at the ecu which is powering the injectors when it shouldnt. however this is not a fault i have come across on a pd engine but have seen it on a td5 landy, which uses the same sort of injectors, but eys, to have 3 fail would be unheard of, which is why an electrical problem may be the culprit.
  7. Re: About to cry! 1.9 tdi flooding with diesel
    Jul 2015
    Staffs
    46 Post(s)
    Injector loom?
    Ian
    A4 B6 Avant Nogaro Blue
    0 2 0
  8. Re: About to cry! 1.9 tdi flooding with diesel
    Aug 2016
    N.wales
    I'm waiting for the barttery to charge back up but noticed the temp gauge is now stuck on max and hasn't ran? Unplugged the loom and once oil stopped coming out of cyl 3 made no difference plugged or unplugged
    0 2 0
  9. Re: About to cry! 1.9 tdi flooding with diesel
    Aug 2016
    N.wales
    Turns out its oil going in the cylinders not diesel.out of my hands scrappy she goes I think
    0 3 0
  10. Re: About to cry! 1.9 tdi flooding with diesel
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Blown turbo passing oil. Intercooler must be full of oil. Bad luck mate.
    Alan.
    VW T6 150 DSG Camper £££
  1. Flooding floorwells
    By jojocags in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 08:38 PM
  2. cry for help vag
    By arron9999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-08-2010, 07:25 AM
  3. Please Help Flash Flooding
    By scottjay86 in forum Chat - Anything with wheels
    Last Post: 22-05-2009, 10:45 PM
  4. Car would not start- flooding
    By dermot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 11:14 PM
  5. Flooding and your motoring woes
    Last Post: 23-07-2007, 11:19 PM
