Thread: Aircon not working
Results 1 to 10 of 10
  1. Aircon not working
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi all, my Dad has an A6 2007 2.0l tdi 140bhp BRE engine code (i think)
    anyway the aircon hasnt really worked this year, so i plugged it into VCDS and was suprised to see no faults found on the aircon, it was showing pressure in the system. So thought it was just a re gassing. The auto button works but the fans dont come on in the enginebay, however they will come on when doing an output test with VCDS, I Took it in to be regassed today, and they confirmed there was very little refrigerant, 55g i think he said, and it should be over 500, but there are no leaks, but alass still no working aircon. After an hours drive tonight there was a very slight chill to the air, but still not enough to chill the cabin, and no fans on, with the bonnet open and engine running there seems like no click or rev change when i click between econ and auto, so i suspect the compressor has failed, but wouldnt this register a fault? Or am i barking up the wrong tree?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: Aircon not working
    May 2014
    Darlington
    78 Post(s)
    Unfortunately you are looking up the wrong tree, the aircon pump is a dumb bit if kit, it's a basic pump with a single wire going into it to activate the clutch on the compressor. If it's dead you won't get any fault codes and no aircon.
  3. Re: Aircon not working
    Feb 2009
    Ireland
    Check the pulley first. Known to break up and just free wheel.
    Does the pressure value change in VCDS when you switch Econ off. It should.
  4. Re: Aircon not working
    Dec 2007
    44 Post(s)
    Refrigerant circuit pressure remains 6.6bar on auto with econ on or off.
  5. Re: Aircon not working
    Feb 2009
    Ireland
    Take the cover off the front of the a/c pulley. I'd say it's sheared. Which it's designed to do in an overload condition. There only about £60. I've had to change 3 on 3 different family members A6's.
  6. Re: Aircon not working
    Jun 2012
    Ireland
    *Bandwagon* So I did the oil service on my 2007 A6 and when dropping the sump guard the pulley/clutch cover was lying on it. It has sheared off from the shaft,as designed. Can one point me to where I could get the pulley/clutch kit mentioned?
    Sent from my D6603 using Tapatalk
  7. Re: Aircon not working
    Dec 2007
    44 Post(s)
    so an update on this, i have swapped the Pressure switch in the condenser and the quality switch under the rain tray. cleared the codes and within 20 seconds these come back.
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Control Module Part Number: 4F0 910 043 HW: 4F2 820 043 N
    Component and/or Version: KLIMABETAETIGUNGH20 0170
    Software Coding: 0001302
    Work Shop Code: WSC 02325 785 00200
    VCID: 5BB5B4E29A03B89F39-800E
    3 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    01858 - Air Outlet Sensor; Right Center (G348)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    01592 - Air Quality Sensor (G238)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    Freeze Frame:
    Temperature: 20.0°C
    so im thinking a broken wire? but where
    also my control panel and fans are working again.
  8. Re: Aircon not working
    Dec 2007
    44 Post(s)
    Also my pressure is showing as 90 PSI and in the red on my pressure gauge.
  9. Re: Aircon not working
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by dean warren View Post
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 70
    Mileage:
    Time Indication: 0
    Date: 2017.06.09
    Time: 12:32:32
    Freeze Frame:
    Temperature: 20.0°C
    Didn't you say initially you had no AC fault codes?
    Fans not working?....any engine codes related to this problem?
    Ian
    A4 B6 Avant Nogaro Blue
  10. Re: Aircon not working
    Dec 2007
    44 Post(s)
    Quote Originally Posted by rowdy-999 View Post
    Oh dam ive posted it on the wrong thread
    By bear1987 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2016, 01:01 PM
  2. A4 B6 Aircon not working
    By gavsman in forum VCDS - Help Requests
    Last Post: 20-04-2011, 01:45 PM
  3. do you think my aircon is working ok?
    By tom tom in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 09-01-2010, 05:27 PM
  4. Is my aircon working right?
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2009, 09:53 PM
  5. non working aircon
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2008, 09:38 PM
