Thread: EPC and traction control light comes on and then car goes into limp mode.
  1. EPC and traction control light comes on and then car goes into limp mode.
    Jun 2016
    Dublin
    Hey,
    I have a 2004 A3 1.6, every so often the epc and traction lights comes on and the car go's into limp mode. When I turn the car off and back on and it clears it and it might not happen again then for a few weeks. Then it might happen 3/4 times while I'm driving an hour down the road. I had my mate plug the car into his comp and get the fault codes. So hoping someone might have an idea what might be causing it. I have noticed that the wire loom going to the throttle body had been cut and reconnected just before it plugs into the throttle body, the last owner had cut and rejoined for what I don't know. but the connections look ok.
    Thanks in advance.
    3 Faults Found:
    17950 - Angle Sensor 1 for Throttle Actuator (G187)
    P1542 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    RPM: 4224 /min
    Bin. Bits: 00001000
    Load: 81.6 %
    Load: 31.0 %
    17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
    P1171 - 008 - - Intermittent
    Freeze Frame:
    RPM: 4032 /min
    Bin. Bits: 00100000
    Load: 37.3 %
    Load: 82.7 %
    Freeze Frame:
    RPM: 4224 /min
    Bin. Bits: 00001000
    Load: 81.6 %
    Load: 31.0 %
  2. Re: EPC and traction control light comes on and then car goes into limp mode.
    Jun 2016
    Glasgow
    Well those faults certainly look like there may be an issue with the throttle unit/wiring (if the codes are permanent).
    I presume these codes were pulled from the engine ecm. Are you able to do a scan of the ABS module? If you can post those codes, that would be helpful.
  3. Re: EPC and traction control light comes on and then car goes into limp mode.
    Jun 2016
    Dublin
    I got another scan done. Again the car is driving fine. The odd time to while I'm sitting at traffic lights I notice the car revs a little uneven. revs past 1000 then just drops back to around 600/700 then back up past 1000. The aircon is off too when that happens.
    Thanks in advance.
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: Mileage: 179320km/111424miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 06A-906-033-BGU.lbl
    Part No: 06A 906 033 DS
    Component: SIMOS71 1.6l 2V 5559
    Revision: --H03--- Serial number: AUX7Z0D2FN90LD
    Coding: 0000071
    Shop #: WSC 06435 000 00000
    VCID: 73E247E312A68F8696F-8026
    5 Faults Found:
    Freeze Frame:
    RPM: 896 /min
    Bin. Bits: 00001000
    Load: 9.8 %
    Load: 78.4 %
    RPM: 704 /min
    Bin. Bits: 00001000
    Load: 9.8 %
    Load: 78.8 %
    Freeze Frame:
    Mass Air / Rev.: 261.6 mg/str
    Bin. Bits: 00000100
    Load: 31.4 %
    Load: 85.5 %
    Mass Air / Rev.: 256.2 mg/str
    Bin. Bits: 00001000
    Load: 35.7 %
    Load: 80.0 %
    Freeze Frame:
    Bin. Bits: 00000100
    Load: 31.4 %
    Load: 85.5 %
    Bin. Bits: 00001000
    Load: 35.7 %
    Load: 80.0 %
    P1542 - 007 - Implausible Signal - Intermittent
    Freeze Frame:
    Bin. Bits: 00000100
    Load: 31.4 %
    Load: 85.5 %
    Bin. Bits: 00001000
    Load: 35.7 %
    Load: 80.0 %
    17796 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 - 008 - - Intermittent
    Freeze Frame:
    Bin. Bits: 00101010
    Hex Value: 0x0028
    Hex Value: 0x0001
    Hex Value: 0x0002
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0019077
    VCID: 3A7CAAC7754C3ECE959-806F
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
  4. Re: EPC and traction control light comes on and then car goes into limp mode.
    Jun 2016
    Glasgow
    If the wiring loom has been messed with, its integrity should be checked first.
    If it tests okay, I'd give the throttle a clean and relearn the control stops (basic settings) with VCDS. At this point, ideally, air intake should also be checked for leaks. Also worth monitoring throttle position and accelerator pedal position in measuring blocks (plot on graph).
    Let us know how you get on.
    Good luck.
  5. Re: EPC and traction control light comes on and then car goes into limp mode.
    Sep 2016
    Norwich
    I had a very similar problem. Kept going into limp mode under hard acceleration. Turned out to be the turbo actuator.
  6. Re: EPC and traction control light comes on and then car goes into limp mode.
    Nov 2016
    Sofia
    dontclickonthis, do you have updates on this issue? Tomorrow I'll take my 2006 Audi A4 1.8T to service center, with exactly the same error codes and vehicle reaction. I will write back soon, I hope
  7. Re: EPC and traction control light comes on and then car goes into limp mode.
    Nov 2016
    Sofia
    FIXED.
    After a month in a service center, changed Speed sensor, cleaning and adapt Throttle body, the issue still was active. Finally we try with Throttle body replacement.
    Not a solution
    Finally, in different service center, the reason was found. Water in the computer. It was able to be repaired, for my luck.
    Guys, check your computers FIRST, before taking a decision for parts replacement.
    Good luck
  1. Emission control system light on and car in limp home mode
    By jkl123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2012, 12:04 AM
  2. ESP EPC then Emissions lights. Car in limp mode
    By wobblish in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2012, 02:38 PM
  3. EPC light on - limp mode - 2.0TFSi
    By TFSIer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-03-2010, 06:47 PM
  4. Please Help EPC and traction light then LIMP MODE help anyone?
    By dtwoi in forum Audi A3 - Archive Topics
    Last Post: 01-11-2008, 08:27 AM
  5. passat epc warning light and limp mode
    By thebear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 11:51 PM
