Thread: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
Results 1 to 10 of 11
  1. 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Hi, my son's 2008 Polo with 1.2 BBM engine keeps showing the following fault codes:
    16726 - Camshaft position sensor (G40): Signal too low
    P0342 - 009 - Open or short to ground - Intermittent
    01314 Engine Control Module
    013 - check DTC Memory - Intermitent
    18265 - Load Signal: Error Message from ECU
    P1857 - 000 - -- Intermittent
    The fault clears ok, but then comes back and occasionally displays an engine management light. The car runs fine, sometimes it seems to limit the revs to 5000 but then after a switch off/on its fine.
    After reading several threads, I replaced the camshaft sensor, I then checked the timing - it was very slightly out so adjusted it so its spot on and then rechecked after a few miles. None of this has corrected the fault reading.
    Any ideas where to look next, the engine seems fine but I'd like to get to the bottom of this fault code issue?
    Thanks in advance.
  2. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    131 Post(s)
    1973 Post(s)
    It could be suffering from chain system wear so the timing is unstable. Did you use the cam and crank locking pins?
  3. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Thanks Crasher, yes affirm I used the locking pins and adjusted as per manual. When I checked after a week of driving it was still spot on.
  4. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    131 Post(s)
    1973 Post(s)
    You would have had the sump off to reset the timing so you can discount a blocked oil pick-up being the cause so I would say fit a timing chain set, they are not very expensive and I would have done it anyway with it stripped down. We sell the Febi kit for £111.74 and it comes with two gears, chain, tensioner and two sliders.
  5. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Thanks, yes I did think at the time it would have been worth doing the chain when the cover was off..... Just looking at Febi kits is it kit 30495 with 118 links?
  6. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Ok, replaced the timing chain, sprockets, guides and tensioner using the Febi kit 30495. No problems fitting, the old chain did look worn and the car runs great and the engine management light went out after about a minute of running.
    I then cleared all the old fault codes and took it for a drive all fine and pulls well. However, when I checked the fault codes at home it is still showing the camshaft sensor fault and the ECU error. Here is a pic of the exact codes. Anyone any ideas, on what to try next?:
  7. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    131 Post(s)
    1973 Post(s)
    Did you use locking tools?
  8. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Yep, followed all the procedures as per EW. Checked the timing after and it remained spot on.
  9. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    131 Post(s)
    1973 Post(s)
    Change the sensor now and hope that cures it...
  10. Re: 1.2 Polo Camshaft Position Sensor Error even after timing corrected?
    Ok it’s been a while but the problem hasn’t gone away. Is it worth changing the ecu?
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  3. Please Help A4 20v turbo Camshaft Position Sensor error P0343
    By Matty Jones in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2010, 03:03 PM
  4. camshaft position sensor error
    By glen70 in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2009, 01:31 AM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
